connecting a WS-C4948 to a Nexus 5010
jdanan371
Beginner
Beginner
is it possible to connect a WS-C4948 switch to a Nexus 5010? I have a flat network with no vlans.I know you are suppose to use the first 8 ports of the Nexus to get it to be on a 1GB port. What gbic am i to use on the ws-c4948 switch? if using a fiber cable or a rj45 cable?
You config on the Nexus is not correct.  You need to remove the ip address on the managment interafce and assign it to vlan 1 and add interface e1/1 to vlan 1, which should be default.
configuration on Nexus 5010:
interface Ethernet1/1
speed 1000
vrf context management
ip route 0.0.0.0/0 10.x.x.1
interface mgmt0
no ip address 10.x.x.223/8
interface vlan 1
ip address 10.x.x.238/8
no sh
now, you should be able to ping from the 5k to the 4849
6 Replies 6
Leo Laohoo
VIP Community Legend VIP Community Legend
Yes you can.
You must be aware that Nexus has BPDU Guard PERMANENTLY turned on.  So when you connect your switch to Nexus 5K the port will immediately go into "error disable".
The only way around this is to disable STP portfast on the Nexus 5K side.
WS-C4849 <---------------> Nexus 5010 (connected with a cat 6 ethernet cable)
WS-C4849 interface GigabitEthernet1/48
Nexus 5010 interface Ethernet1/1 (using a Cisco 1000BASE-T SFP Transceiver Module for Category 5 copper wire, spare
Mfg. Part#: GLC-T )
configuration on WS-C4849:
interface GigabitEtherenet1/48
media-type rj45
interface Vlan1
ip address 10.x.x.226 255.0.0.0
ip default-gateway 10.x.x.1
speed 1000
vlan 1
interface mgmt0
I have green lights on these ports, and showing interface is saying that the interface is up and connected.
what else would I need to configure to pass traffic between them?
Leo Laohoo
Configure the ports to be 802.1q Trunking.
speed 1000
interface mgmt0
interface vlan 1
no sh
I was able to get it to work.....thank  you for the guys who responded!!
configuration on the WS-C4948:
description connection to nexus5010
media-type rj45
interface Vlan1
configuration on the Nexus 5010:
vlan 1
interface Vlan1
  no shutdown
  switchport mode trunk
  speed 1000
steps on adding vlan 1 and adding an IP address on the Nexus 5010:
- remove int mgmt 0, ip address and vrf context management
nexus5010(config)# int mgmt 0
nexus5010(config-if)# no ip address
nexus5010(config-if)# vrf context management
nexus5010(config-vrf)# no ip route 0.0.0.0/0 10.x.x.1
nexus5010(config-vrf)# exit
- turn on feature interface-vlan, create int vlan 1, add IP address, no shut, add vrf context default
nexus5010(config)# feature interface-vlan
nexus5010(config)# int vlan 1
nexus5010(config-if)# ip address 10.x.x.223/8
nexus5010(config-if)# no shut
nexus5010(config-if)# exit
nexus5010(config)# vlan 1
nexus5010(config-vlan)# exit
nexus5010(config)# vrf context default
nexus5010(config)# ip route 0.0.0.0/0 10.x.x.1
nexus5010(config)# exit
Your Nexus config looks good now.
If you ever want to manage the switch using the out of band port (mgmt0) you need to give it an IP address:
Example:
nexus5010(config-if)#ip address 192.168.1.1/24
Recognize Your Peers
