Connecting Cisco switch with 3rd party switch via fibre trunk
Hi All
can anyone assist with the following
I am trying to connect a Cisco 250 series switch to an industrial DLink switch DIS-200G-12PS
via a fibre trunk link using Chimera GBics 10G Sfp interfaces
If I connect both switches using a copper link it works fine.
I have proven the LC patch lead
I have proven the GBics
I can see the GBic in system status though fibre link is down
it looks as though there’s a protocol problem or handshake issue but I’m guessing
any assistance greatly appreciated
Rob Davies
Mark Elsen
          - Check the  logs on both platforms, when trying to establish the link.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hello
The fibre sfps need to be compatible to the fibre you are using and between each other, be it
Short hual (SX) or Long haul (LX), Multimode (MM) or Sinlge mode (SM) sfps
Kind Regards
Paul
Thanks for reply
I’ve since checked the spec of both switches and found the Dlink switch sfp port is 1000M while the Cisco switch ports are SFP+ so think this is probably my issue
