Connecting FEX to Nexus 7K Parent switch
dtran
Level 6
Level 6
Hi all,
Hope everyone is doing well !!! I am looking into connecting the FEX to the N7K parent switch and have a couple questions. Thanks in advance for any inputs / suggestions.
I understand that FEX can be connected to its parent switch through a port channel and in my scenario I will have host systems that will be connected to the FEX that are on different VLANs. My question is do I need to set up the port channel in trunk mode to allow different VLANs passing through ? below is what I think the config would look like. Please verify the config below for me !!!
config t
interface port-channel 10
switchport mode fex-fabric
fex associate 110
switchport
switchport mode trunk
config t
interface e1/1
fex associate 110
channel-group 10
switchport
config t
interface e1/2
fex associate 110
channel-group 10
switchport
Marwan ALshawi
Because the Nexus 2000 fabric extender acts as a remote line card to the parent switch, all the configuration takes place on the parent Switch, the N7K in your case
for fabric extender interfaces they have to be in fex-fabric mode this not normal L2 etherchannel it is fabric expansion
example:
(config)#
fex 100
(config-fex)#
pinning max-links 1
switch# configure terminal
switch(config)# interface port-channel 4
switch(config-if)# switchport mode fex-fabric
switch(config-if)# fex associate 100
switch(config-if)# exit
switch(config)# interface ethernet 1/37
switch(config-if)# channel-group 4
switch(config)# interface ethernet 1/38
A fabric interface includes the corresponding interface on the parent switch. This interface is enabled when you enter the switchport mode fex-fabric command.
if helpful Rate
7 Replies 7
Marwan ALshawi
example:
(config)#
fex 100
(config-fex)#
pinning max-links 1
if helpful Rate
Hi Marwan !! Thanks for your help !!!
I understand the N2K acts as a remote line card to the parent switch, so all vlans is allowed through the port channel correct ? do I need the "switchport" and the "switchport mode trunk" commands ?
Thanks again !!
Danny
Marwan ALshawi
No, the mode is fex
Got it,
So by default all VLANs are allowed through the port channel ? Do I need the "switchport" command ?
Thanks Marwan !!!
D.
Marwan ALshawi
For the FEX ports just use the commands in the example above
Once the FEX get discovered and associated in the parent switch you will see ports like 100/x/x. There you can configure vpc, trunk ..etc
Thanks Marwan !!! I will give it a shot !!! I appreciate all your help !!!
D>
thanks for the nice rating
and just for your reference use the bellow config guide
