Connecting fortigate to Cisco Core
Chris McCann
HI,
I have a problem, we have a failover fortigate FW pair both linking to a single switch which then has a trunk connecting to our core switch.
If I remove the single switch and run the pair of cables from the fortigate into the core then the FW fails and the ports on the core do not come up. I have the ports on the core configured as access ports.
The switch being removed has almost no config on it. the interfaces to the FW are access vlan 4, back to the core the interface is trunk.
Here is the config from the core switch.
Trunk port that links to the switch I want to remove.
interface GigabitEthernet2/29
description Primary-InsideFirewall
switchport
switchport mode trunk
spanning-tree portfast edge
end
interface Vlan4
description Firewall VLAN
ip pim sparse-mode
end
I have configure the two new ports as below,
GI2/30
switchport
switchport mode access vlan 4
end
Gi1/30
description Secondary-InsideFirewall
switchport
end
But as mentioned when patching direct into the core switch the ports fail to come up.
I got this from the CISCO log.
.Sep 10 07:10:08: %PIM-5-NBRCHG: neighbor 192.168.1.2 DOWN on interface Vlan4 DR
.Sep 10 07:10:08: %PIM-5-DRCHG: DR change from neighbor 192.168.1.2 to 192.168.1.1 on interface Vlan4
.Sep 10 07:16:20: %PIM-5-NBRCHG: neighbor 192.168.1.2 UP on interface Vlan4
.Sep 10 07:16:20: %PIM-5-DRCHG: DR change from neighbor 192.168.1.1 to 192.168.1.2 on interface Vlan4
192.168.1.2 is the firewall virtual IP,
192.168.1.1 is the core SVI interface for that particular vlan. The second part in bold is when I patched the orginal single switch back in and the FW comes back up.
I know very little about IP PIM. However from my understand since the firewall and core SVI are in the same vlan this should make no difference.
Any advise welcome!
Chris
Slightly concerned about doing this as we also have some servers in the same vlan which may be effected. I was also thinking that the SVI shouldnt really come into play as all the interfaces involved are in the same vlan.
This is a live enviroment so I cant go playing around too much. I have to plan the work and do out of hours.
5 Replies 5
Reza Sharifi
A couple of questions:
Are the firewalls clustered?
Are the core switches stacked?
It appears that when you move the connections from a single switch to the core switches, the core switches don't see the firewall as one unit (clustered or aggregated).
The firewall is a failover pair, active/passive.
The core switch is a single unit 6509 with multiple blades.
Yeah I agree, I though perhaps there was some some of signalling between the two firewall interfaces that was being blocked by the core switch but I dont see what or how.
Ok, so, the core switch is only one. So, we don't need to worry about any switch clustering, aggregation, etc. It may be an STP issue. Can you check the VTP status and make sure it is turned off or it is in transparent mode?
Also, can you make sure that the switch is the root bridge for all vlans?
Since the switch is in production, you would need to make any of these changes during off-hours.
what happens when you disable PIM altogether on the SVI ?
interface Vlan4
--> no ip pim sparse-mode
end
