06-28-2018 08:48 AM - edited 03-08-2019 03:30 PM
With respect to below topology, between Nexus7k and Cisco3750 switch, If all the interface eth1/14,1/15,1/16,2/15 are configured in acces mode and same access vlan, Will it cause a loop ? and what about, if all the interfaces configured with different access vlan? Please advice.
################Nexus7k############
Eth1/14 Eth1/15 Eth 1/16 Eth 2/15
###############3750Sw#############
Sreeraj
06-28-2018 09:21 AM
You should put all interfaces in a Portchannel, so they logically look like one interface, if not STP will block 3 out of 4 interfaces.
06-28-2018 10:34 AM
Thanks, we cannot put in port channel considering securing different service with separate vlans. Will my topology work(with all interface in forwarding), if all interfaces are in placed in different Customer vlans?
06-28-2018 10:51 AM
When you connect multiple switches via redundant physical links, to prevent loop STP will allow one port to be in forwarding mode and the rest in blocking. Also, not using Portchannel (separate links) does not provide any security because everything is still connected to the same 2 switches. If you want to separate customers, you may want to look at VRF.
06-28-2018 11:18 AM
I am pasting the show cdp neighbors command from Nexus7k, currently in the network the Nexus 7k is connected to 3750 switch, the way, i mentioned previously. Please help, how this connectivity is working then,all in forwarding state. Please let me know, for any other output.
LINY-N77K01-PROD# show cdp neighbors
Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge
S - Switch, H - Host, I - IGMP, r - Repeater,
V - VoIP-Phone, D - Remotely-Managed-Device,
s - Supports-STP-Dispute
Device-ID Local Intrfce Hldtme Capability Platform Port ID
LINY-3750-01M.highstreetit.com
mgmt0 147 R S I WS-C3750G-24T Gig1/0/5
usny01ethr002.hitscs.local.hitscs.local(FOX1829GY21)
Eth1/9 140 S I s N5K-C5596UP Eth1/9
usny01ethr001.hitscs.local.hitscs.local(FOX1750GLYE)
Eth1/10 172 S I s N5K-C5596UP Eth1/10
usny01ethr003.hitscs.local.hitscs.local(FOC1737R05G)
Eth1/11 163 R S I s N3K-C3048TP-1 Eth1/38
Eth1/12 164 R S I s N3K-C3048TP-1 Eth1/37
Eth1/14 138 R S I WS-C3750G-24T Gig2/0/12
Eth1/15 147 R S I WS-C3750G-24T Gig1/0/12
Eth1/16 147 R S I WS-C3750G-24T Gig1/0/13
Eth2/9 172 S I s N5K-C5596UP Eth1/9
Eth2/10 140 S I s N5K-C5596UP Eth1/10
usny01ethr004.hitscs.local.hitscs.local(FOC1737R05M)
Eth2/11 165 R S I s N3K-C3048TP-1 Eth1/38
Eth2/12 165 R S I s N3K-C3048TP-1 Eth1/37
Eth2/15 147 R S I WS-C3750G-24T Gig1/0/10
DECO-N77K01-PROD(FXS1836Q2BB)
Eth2/24 158 R S s N77-C7706 Eth2/24
Please find the show spanning tree output from 7k
LINY-N77K01-PROD# show spanning-tree interface ethernet 1/15 detail
Port 143 (Ethernet1/15) of VLAN1004 is designated forwarding
Port path cost 4, Port priority 128, Port Identifier 128.143
Designated root has priority 25580, address 002a.6a5c.95c2
Designated bridge has priority 25580, address 002a.6a5c.95c2
Designated port id is 128.143, designated path cost 0
Timers: message age 0, forward delay 0, hold 0
Number of transitions to forwarding state: 4
Link type is point-to-point by default
BPDU: sent 26861601, received 123794
LINY-N77K01-PROD# show spanning-tree interface ethernet 1/14 detail
Port 142 (Ethernet1/14) of VLAN0903 is designated forwarding
Port path cost 4, Port priority 128, Port Identifier 128.142
Designated root has priority 25479, address 002a.6a5c.95c2
Designated bridge has priority 25479, address 002a.6a5c.95c2
Designated port id is 128.142, designated path cost 0
Number of transitions to forwarding state: 1
BPDU: sent 869237, received 51
LINY-N77K01-PROD# show spanning-tree interface ethernet 1/16 detail
Port 144 (Ethernet1/16) of VLAN0136 is designated forwarding
Port path cost 4, Port priority 128, Port Identifier 128.144
Designated root has priority 24712, address 002a.6a5c.95c2
Designated bridge has priority 24712, address 002a.6a5c.95c2
Designated port id is 128.144, designated path cost 0
BPDU: sent 26986166, received 19
LINY-N77K01-PROD# show spanning-tree interface ethernet 2/15 detail
Port 271 (Ethernet2/15) of VLAN1004 is designated forwarding
Port path cost 4, Port priority 128, Port Identifier 128.271
Designated port id is 128.271, designated path cost 0
Number of transitions to forwarding state: 6
BPDU: sent 26986181, received 123752
Sreeraj
06-29-2018 06:47 AM
Hi Experts,
Can some one help please ?
Thanks & Regards
Sreeraj
