Cisco Logging level question
dbuckley77
Level 5
Level 5
Currently we have logging level set to 7 debugging on our switches and we're seeing mostly interface up/down messages coming through to our syslog server.  I have been asked to setup logging so that we also see traps sent any time a user logs into a switch in  our syslog server.  Is this possible to do and which logging level should I set to accomplish this?
Daniele Giordano
Level 11
Level 11
Hi, you can try using access-list logging function.
For instance:
conf t
access-list 23 permit ..... log
line vty 0 4
access-class 23 in
Regards.
You can use the command "login on-success log" to log the username when someone logs into a switch. If you want to log login failures you can use "login on-failure log" command also.
