Connecting Static routed networks to dynamic routed networks
Hi Everyone,
I have 11 networks configured in the Packet tracer. the 5 networks on the right are configured with the static routes. And 5 networks on the right side which are configured with dynamic routes. There is an 11th network "192.168.10.0" through which I want to connect the static side with the dynamic side. So that I can ping the "PC0" with "PC1".
How can I do that?
Swedberg
I was using 193.168.0.0/16 network and had an issue, because 193. isn't a private network space. Have you found the solution?
Zach
Zach Swedberg
learningnetwork.cisco.com/s/question/pc0-should-ping-pc1 writemyessaysonline.com
