Connecting two CBS350 Switches
ryujin7177
I've two CBS350 series of switches that I wish to setup for connecting IP Cameras and accessing them from the Control Room.
IP Cameras will be connected to CBS350-8S-E-2G.
CBS350-8S-E-2G will be connected to CBS350-24T-4X over Single mode fiber via a pair of GLC-LH-SMD 1Gbit SFP
For testing purposes, I'm trying to ping a PC connected at gi10 (in CBS350-8S-E-2G) from a PC at gi1/0/24 (in CBS350-24T-4X), but unable to do so. I can successfully ping the switches themselves from PC (IPv4 address of VLAN 2 interface).
I'm attaching my "running-config" from both of these switches and layout diagram.
Please help.
@ryujin7177
 If should work. Can you ping from one switch to another?  Check the PC config also, make sure there was not mistake on the IP address or mask
balaji.bandi
In Generaly that should work, if not work i would check first :
1. show interface status is the both the side 1/0/1 and Gig9 working
2. show spanning tree for vlan 2
3. i would also replicate the config both the side to see any difference, either user Trunk or allow vlan x-x (both the side) for consistancy.
4. are you able ping from switch IP to Switch IP that is 102 to 103 or 103 to 102 ?
5. show ip interface brief will help you if switch to switch not pinging.
6. check show ip arp mac address table see are you lerning anything from trunk
7. check PC has any firewalls and check does the switch can ping PC ?
BB
amitspanchal
Try by adding the command trunk allowed vlan all on the uplink interface of the CBS350-8S-E-2G switch.
