Bookmark
Subscribe
726
Cisco 2960-S MBIST failed
leesince004
Hello there,
we've recently been resetting some of our Cisco 2960-S series switches, and we are getting some weird post messages.
When we boot into ROMMON and factory reset them, after the boot command when the firmware boots, we get 9 MBIST fails, but the switch boots up normally. After it boots and we restart it without going into ROMMON, the MBIST fails are not there.
Below are the console logs for both ROMMON and the fails.
The system has been interrupted prior to initializing the
flash filesystem.  The following commands will initialize
the flash filesystem, and finish loading the operating
system software:
    flash_init
    boot
switch: flash_init
Initializing Flash...
mifs[2]: 10 files, 1 directories
mifs[2]: Total bytes     :    1806336
mifs[2]: Bytes used      :     612352
mifs[2]: Bytes available :    1193984
mifs[2]: mifs fsck took 1 seconds.
mifs[3]: 0 files, 1 directories
mifs[3]: Total bytes     :    3870720
mifs[3]: Bytes used      :       1024
mifs[3]: Bytes available :    3869696
mifs[3]: mifs fsck took 0 seconds.
mifs[4]: 5 files, 1 directories
mifs[4]: Total bytes     :     258048
mifs[4]: Bytes used      :       9216
mifs[4]: Bytes available :     248832
mifs[4]: mifs fsck took 1 seconds.
mifs[5]: 5 files, 1 directories
mifs[5]: Total bytes     :     258048
mifs[5]: Bytes used      :       9216
mifs[5]: Bytes available :     248832
mifs[5]: mifs fsck took 0 seconds.
 -- MORE --
mifs[6]: 565 files, 20 directories
mifs[6]: Total bytes     :   57931776
mifs[6]: Bytes used      :   15288320
mifs[6]: Bytes available :   42643456
mifs[6]: mifs fsck took 15 seconds.
...done Initializing Flash.
switch: dir flash:
Directory of flash:/
    2  drwx  512       <date>               online_diag
    3  -rwx  1915      <date>               private-config.text
    4  -rwx  3096      <date>               multiple-fs
    5  -rwx  2636      <date>               config.text
    6  drwx  512       <date>               c2960s-universalk9-mz.122-55.SE7
42643456 bytes available (15288320 bytes used)
switch: del flash:config.text
Are you sure you want to delete "flash:config.text" (y/n)?y
File "flash:config.text" deleted
switch: boot
Loading "flash:/c2960s-universalk9-mz.122-55.SE7/c2960s-universalk9-mz.122-55.SE7.bin"
File "flash:/c2960s-universalk9-mz.122-55.SE7/c2960s-universalk9-mz.122-55.SE7.bin" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 12.2(55)SE7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 28-Jan-13 10:28 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01B00000
Initializing flashfs...
Using driver version 1 for media type 1
mifs[3]: 10 files, 1 directories
mifs[3]: Total bytes     : 1806336
mifs[3]: Bytes used      : 612352
mifs[3]: Bytes available : 1193984
mifs[3]: Initialization complete.
mifs[4]: 0 files, 1 directories
mifs[4]: Total bytes     : 3870720
mifs[4]: Bytes used      : 1024
mifs[4]: Bytes available : 3869696
mifs[4]: mifs fsck took 0 seconds.
mifs[4]: Initialization complete.
mifs[5]: Initialization complete.
mifs[6]: 5 files, 1 directories
mifs[6]: Total bytes     : 258048
mifs[6]: Bytes used      : 9216
mifs[6]: Bytes available : 248832
mifs[6]: mifs fsck took 0 seconds.
mifs[6]: Initialization complete.
mifs[7]: 564 files, 20 directories
mifs[7]: Total bytes     : 57931776
mifs[7]: Bytes used      : 15284736
mifs[7]: Bytes available : 42647040
mifs[7]: mifs fsck took 0 seconds.
mifs[7]: Initialization complete.
...done Initializing flashfs.
POST: MA BIST : BeginYeti2S88gMdioWr: Unknown status for write operation
***ERR: S88G FC 1   MBIST Unload Activity
***ERR: S88G FC 1   MBIST failed
***ERR: S88G DP Sg1 MBIST Unload Activity
***ERR: S88G DP Sg1 MBIST failed
***ERR: S88G DP Xg1 MBIST Unload Activity
***ERR: S88G DP Xg1 MBIST failed
***ERR: S88G NI 1   MBIST Unload Activity
***ERR: S88G NI 1   MBIST failed
***ERR: S88G FC 0   MBIST Unload Activity
***ERR: S88G FC 0   MBIST failed
***ERR: S88G DP Sg0 MBIST Unload Activity
***ERR: S88G DP Sg0 MBIST failed
***ERR: S88G DP Xg0 MBIST Unload Activity
***ERR: S88G DP Xg0 MBIST failed
***ERR: S88G NI 0   MBIST Unload Activity
***ERR: S88G NI 0   MBIST failed
***ERR: S88G UPB    MBIST Unload Activity
***ERR: S88G UPB    MBIST failed
POST: MA BIST : End, Status Passed
POST: TCAM BIST : Begin
POST: TCAM BIST : End, Status Passed
extracting front_end/front_end_ucode_info (86 bytes)
Waiting for Stack Master Election...
POST: Thermal, Fan Tests : Begin
POST: Thermal, Fan Tests : End, Status Passed
POST: PortASIC Stack Port Loopback Tests : Begin
POST: PortASIC Stack Port Loopback Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
POST: EMAC Loopback Tests : Begin
POST: EMAC Loopback Tests : End, Status Passed
Election Complete
Switch 1 booting as Master
Waiting for Port download...Complete
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960S-48TS-L (PowerPC) processor (revision B0) with 131072K bytes of memory.
Processor board ID FOC1447Y36V
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
52 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : EC:C8:82:D9:2E:80
Motherboard assembly number     : 73-11909-06
Power supply part number        : 341-0327-02
Motherboard serial number       : FOC14432SRA
Power supply serial number      : DCA1441P1CW
Model revision number           : B0
Motherboard revision number     : A0
Model number                    : WS-C2960S-48TS-L
Daughterboard assembly number   : 73-11933-04
Daughterboard serial number     : FOC144743WF
System serial number            : FOC1447Y36V
Top Assembly Part Number        : 800-30950-02
Top Assembly Revision Number    : A0
Version ID                      : V02
CLEI Code Number                : COMGF00ARB
Daughterboard revision number   : A0
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C2960S-48TS-L   12.2(55)SE7           C2960S-UNIVERSALK9-M
Press RETURN to get started!
Thanks in advance!
Looking at the output high level looks ok, we only get in to ROMMON when things gone erased and recover the switch.
that should not impact operation for you as per my view.
BB
balaji.bandi
Save the config, and reboot the Switch and see is all ok ? after reboot -= check show post any errors.
You are running stable version, that should be ok, still you like to test latest verison below informtion can help you.
Also check latest version can help you to fix the issue :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_58_se/release/notes/OL24337.html#wp1042020
BB
Hi @balaji.bandi , thanks for the quick reply!
the MBIST errors only occur when you go through ROMMON, and using "boot" command with or without the config.text.
I have tried booting the switch without going through ROMMON with and without the config.text and every test is passed. Below is the console log.
Base ethernet MAC Address: 08:cc:68:21:ab:00
Xmodem file system is available.
mifs[2]: 12 files, 1 directories
mifs[2]: Bytes used      :     755200
mifs[2]: Bytes available :    1051136
mifs[3]: mifs fsck took 1 seconds.
mifs[6]: 566 files, 21 directories
mifs[6]: Bytes used      :   15286272
mifs[6]: Bytes available :   42645504
mifs[6]: mifs fsck took 30 seconds.
done.
Loading "flash:/c2960s-universalk9-mz.122-55.SE7/c2960s-universalk9-mz.122-55.SE7.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
executing...
           cisco Systems, Inc.
mifs[3]: 12 files, 1 directories
mifs[3]: Bytes used      : 755200
mifs[3]: Bytes available : 1051136
mifs[7]: 566 files, 21 directories
mifs[7]: Bytes used      : 15286272
mifs[7]: Bytes available : 42645504
mifs[7]: mifs fsck took 1 seconds.
  FC 1   MBIST Test Passed.
  DP Sg1 MBIST Test Passed.
  DP Xg1 MBIST Test Passed.
  NI 1   MBIST Test Passed.
  FC 0   MBIST Test Passed.
  DP Sg0 MBIST Test Passed.
  DP Xg0 MBIST Test Passed.
  NI 0   MBIST Test Passed.
  UPB    MBIST Test Passed.
ucode info file is already there
POST: Inline Power Controller Tests : Begin
POST: Inline Power Controller Tests : End, Status Passed
Election Complete
export@cisco.com.
cisco WS-C2960S-48LPS-L (PowerPC) processor (revision E0) with 131072K bytes of memory.
Processor board ID FOC1711Z0K3
Base ethernet MAC Address       : 08:CC:68:21:AB:00
Motherboard assembly number     : 73-11907-08
Power supply part number        : 341-0393-02
Motherboard serial number       : FOC1711058R
Power supply serial number      : DCA1701U0TD
Model revision number           : E0
Model number                    : WS-C2960S-48LPS-L
Daughterboard serial number     : FOC17106WGM
System serial number            : FOC1711Z0K3
Top Assembly Part Number        : 800-30937-03
Version ID                      : V03
CLEI Code Number                : COMGZ00ARC
*    1 52    WS-C2960S-48LPS-L  12.2(55)SE7           C2960S-UNIVERSALK9-M
 Thank you.
BB
Thank you!
