Connecting two Networks from two different ISP's
ecilop2010
I'm having a little trouble with this and not sure why I can't get these two networks to talk to each other.  The reason I need these two networks to talk to each other is so the one site can talk to the domain controller at the other site.  So here is how I have it setup:
Site A - Cisco 877 Router and domain controller.  Has ISP Mediacom
Site B - Cisco 891 Router needs to talk to domain controller at site A.  Has ISP Frontier (the 192.168.254.xx address is from the modem but I believe the modem has a different IP address that is masked because the modem also acts as a router so there is an actual WAN and LAN address and i can get that information if needed)
I have included the configs of the routers, interface outputs, and ip route outputs from each site.  And as of now I can't get these two networks to talk to each other and I am clearly missing something or something is messed up.  Any help or suggestions would be greatly appreciated.   I can obviously send documents or attach documents if need be but was a little leary because of some of the hashs for passwords and keys.
Site A:
Building configuration...
Current configuration : 4846 bytes
version 12.4
no service pad
hostname lincoln
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone Chicago -6
clock summer-time Chicago date Apr 6 2003 2:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-3111320889
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3111320889
revocation-check none
rsakeypair TP-self-signed-3111320889
crypto pki certificate chain TP-self-signed-3111320889
certificate self-signed 01
quit
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 192.168.1.1 192.168.1.19
ip dhcp excluded-address 192.168.1.241 192.168.1.254
ip dhcp pool ccp-pool
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
lease 0 2
ip domain name domainname.org
ip name-server 97.xx.xx.xxx
ip name-server 74.xx.xx.xxx
username johndoe privilege 15 secret 5
archive
log config
hidekeys
ip ssh port 2001 rotary 1
ip ssh version 2
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0
switchport access vlan 2
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description LCA
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Vlan2
description MediaCom
ip address dhcp
ip nat outside
ip forward-protocol nd
ip route 192.168.1.0 255.255.255.0 172.16.10.1
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool ccp-pool 192.168.1.20 192.168.1.240 netmask 255.255.255.0
ip nat inside source list 7 interface Vlan2 overload
ip nat inside source list 8 interface Vlan2 overload
access-list 7 permit 172.16.10.0 0.0.0.255
access-list 8 permit 192.168.1.0 0.0.0.255
access-list 23 permit 10.10.10.0 0.0.0.7
no cdp run
control-plane
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you
want to use.
^C
banner login ^CUNATHORIZED ACCESS IS PROHIBITED!!
^C
line con 0
no modem enable
speed 19200
line aux 0
line vty 0 4
access-class 8 in
exec-timeout 5 0
transport input ssh
scheduler max-task-time 5000
end
lincoln#show interfaces
ATM0 is administratively down, line protocol is down
Hardware is MPC ATMSAR (with Alcatel ADSL Module)
MTU 4470 bytes, sub MTU 4470, BW 4608 Kbit/sec, DLY 80 usec,
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5 AAL2, PVC mode
10 maximum active VCs, 1024 VCs per VP, 0 current VCCs
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
Last input never, output never, output hang never
Queueing strategy: Per VC Queueing
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 unknown protocol drops
FastEthernet0 is up, line protocol is up
Hardware is Fast Ethernet, address is d057.4ce1.592e (bia d057.4ce1.592e)
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
reliability 255/255, txload 1/255, rxload 33/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 6
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 13145000 bits/sec, 1234 packets/sec
5 minute output rate 518000 bits/sec, 720 packets/sec
3857880 packets input, 806248992 bytes, 0 no buffer
Received 81535 broadcasts, 0 runts, 0 giants, 0 throttles
2264820 packets output, 207242375 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 lost carrier, 0 no carrier
FastEthernet1 is up, line protocol is up
Hardware is Fast Ethernet, address is d057.4ce1.592f (bia d057.4ce1.592f)
5 minute output rate 19000 bits/sec, 14 packets/sec
38377 packets input, 24896327 bytes, 0 no buffer
Received 1038 broadcasts, 0 runts, 0 giants, 0 throttles
110773 packets output, 32545986 bytes, 0 underruns
FastEthernet2 is up, line protocol is up
Hardware is Fast Ethernet, address is d057.4ce1.5930 (bia d057.4ce1.5930)
reliability 255/255, txload 3/255, rxload 1/255
Last input 00:00:00, output never, output hang never
Input queue: 0/75/66/0 (size/max/drops/flushes); Total output drops: 0
5 minute input rate 175000 bits/sec, 138 packets/sec
5 minute output rate 1210000 bits/sec, 173 packets/sec
866681 packets input, 492480432 bytes, 0 no buffer
Received 12768 broadcasts, 0 runts, 0 giants, 0 throttles
983605 packets output, 888284488 bytes, 0 underruns
285 unknown protocol drops
FastEthernet3 is up, line protocol is up
Hardware is Fast Ethernet, address is d057.4ce1.5931 (bia d057.4ce1.5931)
reliability 255/255, txload 31/255, rxload 1/255
Last input 00:00:34, output never, output hang never
5 minute input rate 638000 bits/sec, 740 packets/sec
5 minute output rate 12492000 bits/sec, 1208 packets/sec
2323826 packets input, 246854472 bytes, 0 no buffer
Received 12107 broadcasts, 0 runts, 0 giants, 0 throttles
3701197 packets output, 496043279 bytes, 0 underruns
92 unknown protocol drops
NVI0 is administratively down, line protocol is down
Hardware is NVI
MTU 1514 bytes, BW 56 Kbit/sec, DLY 5000 usec,
Encapsulation UNKNOWN, loopback not set
Vlan1 is up, line protocol is up
Hardware is EtherSVI, address is d057.4ce1.592e (bia d057.4ce1.592e)
Description: LCA
Internet address is 192.168.1.1/24
reliability 255/255, txload 34/255, rxload 1/255
5 minute input rate 512000 bits/sec, 745 packets/sec
5 minute output rate 13365000 bits/sec, 1241 packets/sec
2360500 packets input, 207408874 bytes, 0 no buffer
Received 25490 broadcasts, 0 runts, 0 giants, 0 throttles
3824331 packets output, 846895245 bytes, 0 underruns
0 output errors, 1 interface resets
13440 unknown protocol drops
Vlan2 is up, line protocol is up
Description: MediaCom
Internet address is 173.21.39.x/21
reliability 255/255, txload 1/255, rxload 34/255
5 minute input rate 13434000 bits/sec, 1265 packets/sec
5 minute output rate 489000 bits/sec, 742 packets/sec
3911939 packets input, 864341392 bytes, 0 no buffer
Received 81084 broadcasts, 0 runts, 0 giants, 0 throttles
2295467 packets output, 190780250 bytes, 0 underruns
57 unknown protocol drops
lincoln#
lincoln#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 173.xx.32.1 to network 0.0.0.0
97.0.0.0/32 is subnetted, 1 subnets
S 97.xx.xxx.xx [254/0] via 173.xx.32.1, Vlan2
173.xx.0.0/21 is subnetted, 1 subnets
C 173.xx.32.0 is directly connected, Vlan2
C 192.168.1.0/24 is directly connected, Vlan1
S* 0.0.0.0/0 [254/0] via 173.xxx.32.1
Site B
Current configuration : 6654 bytes
! Last configuration change at 15:20:11 chicago Tue Oct 4 2016 by lcaroute
! NVRAM config last updated at 15:21:39 chicago Tue Oct 4 2016 by lcaroute
version 15.0
no service pad
hostname lcamainrouter
boot-start-marker
boot-end-marker
aaa new-model
clock timezone chicago -6
crypto pki trustpoint TP-self-signed-3455530892
 subject-name cn=IOS-Self-Signed-Certificate-3455530892
 rsakeypair TP-self-signed-3455530892
crypto pki certificate chain TP-self-signed-3455530892
 certificate self-signed 02
        quit
ip source-route
ip dhcp excluded-address 172.16.10.1 172.16.10.15
ip dhcp excluded-address 172.168.10.245 172.168.10.254
   import all
   network 172.16.0.0 255.255.0.0
   default-router 172.16.10.1
   lease 0 2
ip cef
no ipv6 cef
license udi pid CISCO891-K9 sn FTX155082P6
archive
 log config
  hidekeys
ip ssh version 2
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
interface Vlan1
 description LCA
 ip address 172.16.10.1 255.255.255.0
 ip nat inside
interface Vlan2
 no ip address
interface Async1
 no ip address
 encapsulation slip
ip default-gateway 172.16.10.1
ip http server
ip nat pool ccp-pool 172.16.10.21 172.16.10.244 netmask 255.255.0.0
ip nat inside source list 7 interface GigabitEthernet0 overload
ip nat inside source list 8 interface GigabitEthernet0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0
access-list 7 permit 192.168.1.0 0.0.0.255
access-list 8 permit 172.16.10.0 0.0.0.255
no cdp run
control-plane
banner exec ^C
this session.
Replace <myuser> and <mypassword> with the username and password you want to
use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE  PUBLICLY-KNOWN
CREDENTIALS
Here are the Cisco IOS commands.
no username cisco
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
 no modem enable
 speed 19200
line aux 0
line vty 0 4
 access-class 8 in
 exec-timeout 5 0
 transport input ssh
end
lcamainrouter#show interface
Async1 is down, line protocol is down
  Hardware is Analog Modem
  MTU 1500 bytes, BW 9 Kbit/sec, DLY 100000 usec,
  Encapsulation SLIP, loopback not set
  Keepalive not set
  DTR is pulsed for 5 seconds on reset
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/0/16 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 6 kilobits/sec
     0 carrier transitions
  Hardware is Fast Ethernet, address is 649e.f3af.80c5 (bia 649e.f3af.80c5)
  5 minute output rate 1000 bits/sec, 1 packets/sec
     16826667 packets input, 3125784356 bytes, 0 no buffer
     Received 29296 broadcasts, 0 runts, 0 giants, 0 throttles
     14081030 packets output, 1089741748 bytes, 0 underruns
FastEthernet1 is down, line protocol is down
  Hardware is Fast Ethernet, address is 649e.f3af.80c6 (bia 649e.f3af.80c6)
  Auto-duplex, Auto-speed
  Hardware is Fast Ethernet, address is 649e.f3af.80c7 (bia 649e.f3af.80c7)
  5 minute input rate 3000 bits/sec, 3 packets/sec
  5 minute output rate 3000 bits/sec, 4 packets/sec
     1077476 packets input, 240063618 bytes, 0 no buffer
     Received 56110 broadcasts, 0 runts, 0 giants, 0 throttles
     1821916 packets output, 366244373 bytes, 0 underruns
FastEthernet3 is down, line protocol is down
  Hardware is Fast Ethernet, address is 649e.f3af.80c8 (bia 649e.f3af.80c8)
FastEthernet4 is up, line protocol is up
  Hardware is Fast Ethernet, address is 649e.f3af.80c9 (bia 649e.f3af.80c9)
  Last input 00:00:15, output never, output hang never
  5 minute input rate 5000 bits/sec, 5 packets/sec
  5 minute output rate 5000 bits/sec, 5 packets/sec
     22117212 packets input, 2169921740 bytes, 0 no buffer
     Received 157940 broadcasts, 0 runts, 0 giants, 0 throttles
     32903408 packets output, 2441261167 bytes, 0 underruns
     21746 unknown protocol drops
FastEthernet5 is up, line protocol is up
  Hardware is Fast Ethernet, address is 649e.f3af.80ca (bia 649e.f3af.80ca)
  5 minute output rate 1000 bits/sec, 2 packets/sec
     185707 packets input, 38133855 bytes, 0 no buffer
     Received 3437 broadcasts, 0 runts, 0 giants, 0 throttles
     1202531 packets output, 175477591 bytes, 0 underruns
FastEthernet6 is up, line protocol is up
  Hardware is Fast Ethernet, address is 649e.f3af.80cb (bia 649e.f3af.80cb)
     57967 packets input, 12288992 bytes, 0 no buffer
     Received 26238 broadcasts, 0 runts, 0 giants, 0 throttles
     1005478 packets output, 108614622 bytes, 0 underruns
FastEthernet7 is up, line protocol is up
  Hardware is Fast Ethernet, address is 649e.f3af.80cc (bia 649e.f3af.80cc)
     14625860 packets input, 3393021540 bytes, 0 no buffer
     Received 2850 broadcasts, 0 runts, 0 giants, 0 throttles
     7851359 packets output, 904805793 bytes, 0 underruns
FastEthernet8 is down, line protocol is down
  Hardware is PQII_PRO_UEC, address is 649e.f3af.80cd (bia 649e.f3af.80cd)
  Auto-duplex, Auto Speed, 100BaseTX/FX
     0 watchdog
GigabitEthernet0 is down, line protocol is down
  Hardware is PQII_PRO_UEC, address is 649e.f3af.80dd (bia 649e.f3af.80dd)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Auto-duplex, 1000Mb/s, media type is RJ45
  output flow-control is XON, input flow-control is XON
     0 watchdog, 0 multicast, 0 pause input
     0 lost carrier, 0 no carrier, 0 pause output
  Hardware is NVI
  Hardware is EtherSVI, address is 649e.f3af.80c5 (bia 649e.f3af.80c5)
  Description: LCA
  Internet address is 172.16.10.1/24
  Keepalive not supported
  5 minute input rate 1000 bits/sec, 2 packets/sec
  5 minute output rate 0 bits/sec, 1 packets/sec
     14674811 packets input, 1116510630 bytes, 0 no buffer
     Received 246381 broadcasts, 0 runts, 0 giants, 0 throttles
     17068682 packets output, 3080953751 bytes, 0 underruns
     13842 unknown protocol drops
  Description: Frontier
  Internet address is 192.168.254.39/24
  Last input 00:00:05, output never, output hang never
     16820671 packets input, 3057279301 bytes, 0 no buffer
     Received 29291 broadcasts, 0 runts, 0 giants, 0 throttles
     13863584 packets output, 965197991 bytes, 0 underruns
lcamainrouter#
lcamainrouter# show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       o - ODR, P - periodic downloaded static route, + - replicated route
Gateway of last resort is 192.168.254.254 to network 0.0.0.0
S*    0.0.0.0/0 [254/0] via 192.168.254.254
      172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.16.10.0/24 is directly connected, Vlan1
L        172.16.10.1/32 is directly connected, Vlan1
      192.168.254.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.254.0/24 is directly connected, Vlan2
L        192.168.254.39/32 is directly connected, Vlan2
Chris
Anuar Shahrin
So you need to access from 192.168.1.X/24 (Site A Lan) to 172.16.10.X/24(remote LAN)?
You need a site-to-site VPN for that purpose.
