connecting two routers to the same switch
burnning_candle
Hi i have two routers connected to the same switch( layer2 or layer3) and i have run on both routers ospf protocols, but both the routers are unable to form adjacencies.
here are my configuration
Router 1
hostname Router1
ip dhcp excluded-address 88.240.12.89
ip dhcp pool acp1
network 88.240.12.88 255.255.255.248
default-router 88.240.12.89
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 88.240.12.89 255.255.255.248
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 0.0.0.0 0.0.0.0 area 0
Router 2
hostname Router2
ip dhcp excluded-address 88.240.12.97
ip dhcp pool AP2
network 88.240.12.96 255.255.255.248
default-router 88.240.12.97
no ip address
duplex auto
speed auto
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 88.240.12.97 255.255.255.248
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
Switch
hostname Switch
ip routing
switchport mode trunk
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
switchport access vlan 10
switchport mode access
interface FastEthernet0/12
switchport access vlan 20
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
acampbell
At layer 3 your 2 routers are in different subnets so they will NEVER form an adjacency.
Router 1
(So that is addresses 89 - 94)
Router 2
(So that is addresses 89 - 102)
The are both in different Vlans too
They need to be the same subnet & vlan
Alex
Regards, Alex. Please rate useful posts.
Hello
R1
ip route 0.0.0.0 0.0.0.0 88.240.12.94
R2
ip route 0.0.0.0 0.0.0.0 88.240.12.102
Switch
interface Vlan10
 ip address 88.240.12.94 255.255.255.248
interface Vlan20
 ip address 88.240.12.102 255.255.255.248
res
Paul
Kind Regards
Paul
