04-09-2013 06:07 PM - edited 03-07-2019 12:43 PM
I tried to connect a 1841 to a Linksys with a static route. I am able to ping from a computer in the 1841 to a computer in the linksys network, but I can't ping from a computer in the Linksys network to a computer in the 1841 network??
Louis
Solved! Go to Solution.
04-10-2013 01:23 AM
Hello Luis,
Anything on the internet interface of the Wireless router will be blocked by default since there is a firewall that is active on the linksys - in this case its port 0. I did a packet tracer too, so you can see the difference. Anything on the LAN (port 1 on the wireless router) - you can ping, however from the WAN you cannot. I have attached my version of PT so you can see too.
Hope this helps
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
04-09-2013 06:11 PM
HI Louis,
Do you have a route back from Linksys to 1841? AS you said there is a static route from 1841 ---Linksys hence the packets flows fine how about the other way ...?
Simple saying you have a route to go but dont have the way to come back.
Inayath
04-09-2013 06:18 PM
I assigned a static IP on the Linksys and the gateway is the address of the port on the 1841.
Louis
04-09-2013 06:20 PM
Hi Louis,
Thanks for the update.Okay now can you please provide me the snapshot of the config?
1- Does linksys router able to reach cisco 1841 ?
2- Are they in the same subnet?
3- If Linksys router able to reach all the host connected to ciso 1841?
Inayath
04-09-2013 06:31 PM
1-no
2-yes
3-no
04-10-2013 01:23 AM
Hello Luis,
Hope this helps
04-10-2013 07:38 PM
Thank you!
Where do you configure the firewall?
Louis
04-10-2013 10:44 PM
Hello Luis, in packet tracer you cannot alter the firewall I think. I will need to check to confirm.
In the security Tab. There is a section for firewall, you can enable or disable.
Hope this helps
http://www.technipages.com/linksys-wrt54g-router-disable-firewall.html
