connection between DHCP Sever on Packet Tracer and Layer 3 switch
johnmcgrath29
Hi All,
I have configured inter vlan routing with static ip addresses successfully then decided I should setup a Dedicated DHCP Server
I believe I have configured it right However something is wrong as I cannot ping Vlan Interfaces form the DHCP Server and I keep getting DHCP Failed APIPA is being used on the end PC's I also checked the status of the interface that is on the L3 Switch that is connected to my DHCP Server. I have connected to the server and IT's Down that's where the issue is I have tried to bounce the interface with "Shut" "No Shut"  I have configured the interface as access that is connected to the server
the default gateway of the DHCP server needs to be in the 192.168.4.0/24 range. You were using the wrong interface (GigabitEthernet0/1) on the L3 switch, with the wrong IP address.
Attached the working file with the DHCP server handing out IP addresses...
5 Replies 5
post the zipped Packet Tracer project (.pkt) file...
Okay just tried to add lab file strangely will not let me do so
Here you go I managed to get it done
Thank you very much for the help and pointing me in the right direction it's usually the simple stuff thanks again
