connection between Switch and ASA
ermionline
Hi Guys
I have Cisco core switch 4503 E and ASA 5525. All the interfaces of the switch and the ASA are gigabit Ethernet. the interface i used to connect the two devices is also gigabit Ethernet but it is not working unless i specifically configure the speed 100. Can you please help me on this?
what category cable are you using ?
balaji.bandi
there is number of reasons :
1. how far is the Switch and ASA ?
2. what kind of cable is this ? Cat 5 / 6 / e ?
3. if possible post the both the side interface configuraiton, show interface output to understand the issue.
BB
Ruben Cocheno
@ermionline
Confirmt that you have the security license on the ASA's that enables the 1 Gbps, that probaably justifies what you only can bring thaat up to 100 mbps.
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
