Connection closed by foreign host
gauravdeshmukh
I'm Using Cisco 3850 switch and was able to log in through SSH with my username earlier, But today I'm getting the error "Connection closed by foreign host". Please help to resolve the issue. I've also tried logging in from another switch but the issue is the same.
5 Replies 5
Jitendra Kumar
Hope you have configured line VTY 0 4
them put blow commands,
line vty 0 4
password kics
login local
Jitendra
As I mentioned above, Earlier I was able to log in through SSH. Configuration changes are not made since then.
marce1000
  - Check switch logs through telnet or (direct connected) console , when this happens.
 M.
what do you have configured on the target switch ? Make sure it looks something like this:
ip domain-name mydomain.com
username admin privilege 15 password cisco
line vty 0 4
transport input ssh
login local
You also might want to try and zeroize, the regenerate the crypto key:
crypto key zeroize
crypto key generate rsa
Please see the configuration below :-
1024
ip ssh version 2
line vty 0 15
no password cisco
transport input ssh
exit
ip ssh authentication-retries 5
ip ssh time-out 90
line vty 0 4
login local
transport input ssh
line vty 5 15
login
