07-18-2022 12:28 AM
Hello experts
having multiple cisco models switch,s looking for options to replace the use of VTP managing VLAN,s.
Solved! Go to Solution.
07-18-2022 12:34 AM
you have multiple options to manage the network.
Automation something called - unimus
Ansible playbooks- propogate VLAN adds/removals
up to 80 device support called CNA
https://www.cisco.com/c/en/us/products/cloud-systems-management/network-assistant/index.html
07-18-2022 12:34 AM
07-18-2022 01:49 AM
Cisco Network Assistant ok and easy
07-18-2022 02:10 AM
which switch models do you have exactly ? As far as I recall, Cisco Network Assistant does not support all the latest IOS versions and device models...
