Connection Issue on the Server
yusuf habibi
Level 3
Level 3
Hi all,
I have a problem with a connection to the server, under normal conditions ping from the PC monitor to the server normally. but sometimes there is a failure that resulted in the PC unable to connect to the server.
If I do change the IP address on the PC monitor, Ping goes back to normal or I do service network restart on the server problem is gone. please help me, im stuck at this moment
see the attachment for topology:
Habibi
Regards, Habibi
Jon Marshall
Habibi
Can you provide more details in terms of what the failure actually is ?
In addition, are the switches (sw3/sw4) L3 switches ie. what device is the 192.168.10.254 configured on ?
Jon
Hi Jon
Initially the pc monitor can ping the server, and vice versa. in some time these devices can not be connected.
sw3 & sw4 is L2 switches, 192.168.10.254 is FW ASA as a Gateway.
thx for your response
Habibi
Regards, Habibi
Expecting that all of the devices have the right subnet-mask then traffic should not reach the Firewall. Traffic should stay on the L2 domain.
That being said:
  1. Do the PC and Server have the IP address configured statically or is via DHCP?
Next time the issue happens Check
  • Try to ping the Firewall from the PC and Server
  • Check the ARP table of the PC/Server
  • Interface status of the switches
sh interfaces fastEthernet x/x switchport
  • Any Err-disabled problem
sh interfaces fastEthernet x/x status err-disabled
  • The MAC address table of the switches
show mac address-table interface fastEthernet x/x (Make sure you see the MAC address of the PC/Server on the right ports)
Hope this helps,
Looking for some Networking Assistance?
Contact me directly at jcarvaja@laguiadelnetworking.com
I will fix your problem ASAP.
Cheers,
Julio Carvajal Segura
http://laguiadelnetworking.com
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hi jcarvaja
ip address configured static
- PC & server able to ping the Firewall
- no problem with the mac address, errdisable, arp table
I assume the problem is on the server, but I am not so sure how to explain this problem
Habibi
Regards, Habibi
