Connection Problem
LinkedIN
Hi guys,
Please we need some one to help me, i cant reach or ping to time attendance device from our vlan, my vlan ID is 10 and TA device Vlan ID 50, i can ping from some devices but from Vlan 70 i cant, otherwise from other PC i can ping normally, no access list installed on my switch.
9 Replies 9
Reza Sharifi
i can give you access if some one need see configuration
Not a good idea to give access to someone you don't know or don't have a contract with.
Anyway, can you provide a diagram of your network and show what VLAN is where and what is working and what is not?
Point out which device is doing the routing for all VLANs? Also, post the output of "sh ip route" from that device.
OK thank you for your advice bro, there is no option sho ip route.
i hope the below pic is understandable
A perfect picture! Thanks.
Questions, all 2960s switches are just layer-2?
Vlan 50 is deployed on the far right switch and vlan 70 on the far left. What is connected to the one in the middle (what vlan)?
Also, can you post "sh run" and "sh ip route" from the Cisco l3 switch?
yes 2960s L2, Vlan 70 deployed
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2021.03.16 21:32:11 =~=~=~=~=~=~=~=~=~=~=~=
User Access Verification
Password:
HQ>ena
Password:
HQ#sho run
Building configuration...
Current configuration : 13806 bytes
! Last configuration change at 16:39:56 amman Tue Dec 15 2020
! NVRAM config last updated at 15:11:39 amman Mon Jan 11 2021
version 15.0
no service pad
service password-encryption
service compress-config
hostname HQ
boot-start-marker
boot-end-marker
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
--More--   address-family ipv6
exit-address-family
enable secret 4 sma8CRrzx7H2hi/iswBN7L7OPLHET2D2rzUDwM3uBhY
no aaa new-model
clock timezone amman 2 0
switch 1 provision ws-c3850-48t
switch 2 provision ws-c3850-48t
ip routing
ip arp proxy disable
ip device tracking
ip dhcp pool WiFi
network 172.200.6.0 255.255.255.0
domain-name 192.168.1.28
default-router 172.200.6.254
dns-server 192.168.1.28 192.168.1.17
option 138 hex c0a8.0133
lease 3
qos wireless-default-untrust
--More--  !
crypto pki trustpoint TP-self-signed-1764038695
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1764038695
revocation-check none
rsakeypair TP-self-signed-1764038695
crypto pki certificate chain TP-self-signed-1764038695
certificate self-signed 01
30820245 308201AE A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 31373634 30333836 3935301E 170D3137 30373331 31333530
31305A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 37363430
33383639 3530819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100A8F3 04E16F2B 21D08A92 228A41A2 21EB58B0 1F79135E 513CE36F 66D32E9C
60705E8B 77162ADF EDD07462 0967039C 68455AA4 229C668F 1D78DF8B EF04C43E
C72DABB2 ADB46341 DD7E158D A6CF3EFF A936EA90 89A0051D 84890533 1D837581
9F15E0F4 A4A4C7B7 E307F4E2 F86AC910 31CFED3D F0AD2EF6 F8A368D4 C4A27C96
2C570203 010001A3 6D306B30 0F060355 1D130101 FF040530 030101FF 30180603
551D1104 11300F82 0D4D616E 61736565 724F696C 4851301F 0603551D 23041830
168014F1 50395CCA F3A3F12B BEACAF1B A9884005 1392C430 1D060355 1D0E0416
0414F150 395CCAF3 A3F12BBE ACAF1BA9 88400513 92C4300D 06092A86 4886F70D
--More--   01010405 00038181 009615EF 1BC06510 D60E4D86 EE13C44F 44AD4E52 30C329D4
AAC9C006 B07987AC EC3DA687 1EE971BC E96D3423 2DF4DC15 5F5FA9E4 8AF49C27
340D24E8 62B8E2D8 4F35EC4D 160AF869 012A6511 EFA5AEA9 8AC3159F 75BA6E94
5AA3B19B D2DFB87C AE25140A A3F65D5E EC173839 BB6D19C5 7CD8DF90 2AB776CB
2C8F937C E0FF240F DC
quit
diagnostic bootup level minimal
identity policy webauth-global-inactive
inactivity-timer 3600
spanning-tree mode rapid-pvst
redundancy
mode sso
ip ftp username admin
ip ftp password 7 052627211E62783B265C4643
--More--  !
class-map match-any non-client-nrt-class
match non-client-nrt
policy-map port_child_policy
class non-client-nrt-class
bandwidth remaining ratio 10
interface Port-channel1
description F2C1S2
switchport mode trunk
interface Port-channel2
description F2C2
interface Port-channel3
description F1C2
--More--  !
interface Port-channel4
description F1C1S2
interface Port-channel5
description F1C1S3
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
negotiation auto
interface GigabitEthernet1/0/1
description F2C1S2
channel-group 1 mode active
interface GigabitEthernet1/0/2
description F2C1S2
--More--  interface GigabitEthernet1/0/3
description F2C2
channel-group 2 mode active
interface GigabitEthernet1/0/4
description F2C2
interface GigabitEthernet1/0/5
description F1C2
channel-group 3 mode active
interface GigabitEthernet1/0/6
description F1C2
interface GigabitEthernet1/0/7
description F1C1S2
channel-group 4 mode active
--More--  !
interface GigabitEthernet1/0/8
description F1C1S3
channel-group 5 mode active
interface GigabitEthernet1/0/9
description IT_Access_Point
switchport access vlan 60
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
description To San Storage2
switchport access vlan 80
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
description Analyzer
interface GigabitEthernet1/0/14
description Storage-Main Nas
--More--   switchport access vlan 80
interface GigabitEthernet1/0/15
description IT-NVR-98
interface GigabitEthernet1/0/16
description Secondary-Main Nas
interface GigabitEthernet1/0/17
description F2#PRINTER#RICO
switchport access vlan 70
interface GigabitEthernet1/0/18
description WAF
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
--More--  interface GigabitEthernet1/0/21
description Pureflex Uplink
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
description To PureFlex
interface GigabitEthernet1/0/24
description PBX
interface GigabitEthernet1/0/25
switchport access vlan 100
switchport mode access
interface GigabitEthernet1/0/26
description NVR-97
--More--  interface GigabitEthernet1/0/27
description To Management PureFlex
spanning-tree portfast
interface GigabitEthernet1/0/28
description To_Main_UPS
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
--More--  !
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
switchport trunk native vlan 100
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
description AIRPORT2-SCREEN
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
description #san-storage-70.223#
interface GigabitEthernet1/0/40
--More--   description #Sanstorage-70.224#
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
--More--  interface GigabitEthernet1/0/48
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface GigabitEthernet2/0/1
description F2C1S2
--More--  interface GigabitEthernet2/0/2
description F2C1S2
interface GigabitEthernet2/0/3
description F2C2
interface GigabitEthernet2/0/4
description F2C2
interface GigabitEthernet2/0/5
description F1C2
interface GigabitEthernet2/0/6
description F1C2
--More--  !
interface GigabitEthernet2/0/7
description F1C1S2
interface GigabitEthernet2/0/8
description F1C1S3
interface GigabitEthernet2/0/9
interface GigabitEthernet2/0/10
interface GigabitEthernet2/0/11
description NAS_Storage_2
interface GigabitEthernet2/0/12
interface GigabitEthernet2/0/13
description WAN Switch P 1
interface GigabitEthernet2/0/14
description Storage-Main NAS
interface GigabitEthernet2/0/15
interface GigabitEthernet2/0/16
description Storage-Secondary NAS
interface GigabitEthernet2/0/17
description AFAQ PC
interface GigabitEthernet2/0/18
interface GigabitEthernet2/0/19
--More--  !
interface GigabitEthernet2/0/20
interface GigabitEthernet2/0/21
description NVR-99
interface GigabitEthernet2/0/22
interface GigabitEthernet2/0/23
interface GigabitEthernet2/0/24
interface GigabitEthernet2/0/25
interface GigabitEthernet2/0/26
--More--  !
interface GigabitEthernet2/0/27
interface GigabitEthernet2/0/28
interface GigabitEthernet2/0/29
interface GigabitEthernet2/0/30
interface GigabitEthernet2/0/31
interface GigabitEthernet2/0/32
interface GigabitEthernet2/0/33
interface GigabitEthernet2/0/34
--More--  !
interface GigabitEthernet2/0/35
interface GigabitEthernet2/0/36
interface GigabitEthernet2/0/37
description To PureFlex_Controller
interface GigabitEthernet2/0/38
interface GigabitEthernet2/0/39
interface GigabitEthernet2/0/40
interface GigabitEthernet2/0/41
--More--  interface GigabitEthernet2/0/42
interface GigabitEthernet2/0/43
interface GigabitEthernet2/0/44
interface GigabitEthernet2/0/45
interface GigabitEthernet2/0/46
interface GigabitEthernet2/0/47
interface GigabitEthernet2/0/48
interface GigabitEthernet2/1/1
interface GigabitEthernet2/1/2
interface GigabitEthernet2/1/3
interface GigabitEthernet2/1/4
--More--  !
interface TenGigabitEthernet2/1/1
interface TenGigabitEthernet2/1/2
interface TenGigabitEthernet2/1/3
interface TenGigabitEthernet2/1/4
interface Vlan1
no ip address
shutdown
interface Vlan10
description IT
ip address 172.200.1.254 255.255.255.0
ip access-group 101 in
ip access-group 102 out
interface Vlan20
description Manegment
ip address 172.200.2.254 255.255.255.0
interface Vlan30
--More--   description Finance
ip address 172.200.3.254 255.255.255.0
interface Vlan40
description IP-Telephone
ip address 172.200.4.254 255.255.255.0
interface Vlan50
description Finger-Print
ip address 172.200.5.254 255.255.255.0
interface Vlan60
description WIFI
ip address 172.200.6.254 255.255.255.0
interface Vlan70
description Users
ip address 172.200.7.254 255.255.255.0
interface Vlan80
description DMZ
ip address 192.168.1.254 255.255.255.0
interface Vlan90
--More--   description B1
ip address 172.200.9.254 255.255.255.0
interface Vlan100
description PureFlex
ip address 192.168.242.254 255.255.255.0
interface Vlan101
ip address 30.30.30.254 255.255.255.0
interface Vlan200
description SW-Vlans
ip address 20.20.20.1 255.255.255.0
ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.1.100
access-list 101 deny ip host 172.200.1.90 host 192.168.1.3
access-list 101 deny ip host 172.200.1.90 host 192.168.1.4
access-list 101 deny ip host 172.200.1.90 host 192.168.1.25
access-list 101 deny ip host 172.200.1.91 host 192.168.1.3
access-list 101 deny ip host 172.200.1.91 host 192.168.1.4
--More--  access-list 101 deny ip host 172.200.1.91 host 192.168.1.25
access-list 101 permit ip 172.200.1.0 0.0.0.255 any
access-list 102 permit ip any any
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password 7 122C0B05172B0F0C2B29752D
login
line vty 5 15
login
wsma agent exec
profile httplistener
profile httpslistener
wsma agent config
wsma agent filesys
--More--   profile httpslistener
wsma agent notify
wsma profile listener httplistener
transport http
wsma profile listener httpslistener
transport https
ap dot11 24ghz rrm channel dca 1
ap dot11 24ghz rrm channel dca 6
ap dot11 24ghz rrm channel dca 11
ap dot11 5ghz rrm channel dca 36
ap dot11 5ghz rrm channel dca 40
ap dot11 5ghz rrm channel dca 44
ap dot11 5ghz rrm channel dca 48
ap dot11 5ghz rrm channel dca 52
ap dot11 5ghz rrm channel dca 56
ap dot11 5ghz rrm channel dca 60
ap dot11 5ghz rrm channel dca 64
ap dot11 5ghz rrm channel dca 149
ap dot11 5ghz rrm channel dca 153
ap dot11 5ghz rrm channel dca 157
--More--  ap dot11 5ghz rrm channel dca 161
ap group default-group
end
HQ#sho ip rout
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
+ - replicated route, % - next hop override
Gateway of last resort is 192.168.1.100 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 192.168.1.100
20.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 20.20.20.0/24 is directly connected, Vlan200
L 20.20.20.1/32 is directly connected, Vlan200
30.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 30.30.30.0/24 is directly connected, Vlan101
L 30.30.30.254/32 is directly connected, Vlan101
172.200.0.0/16 is variably subnetted, 16 subnets, 2 masks
C 172.200.1.0/24 is directly connected, Vlan10
L 172.200.1.254/32 is directly connected, Vlan10
C 172.200.2.0/24 is directly connected, Vlan20
L 172.200.2.254/32 is directly connected, Vlan20
--More--  C 172.200.3.0/24 is directly connected, Vlan30
L 172.200.3.254/32 is directly connected, Vlan30
C 172.200.4.0/24 is directly connected, Vlan40
L 172.200.4.254/32 is directly connected, Vlan40
C 172.200.5.0/24 is directly connected, Vlan50
L 172.200.5.254/32 is directly connected, Vlan50
C 172.200.6.0/24 is directly connected, Vlan60
L 172.200.6.254/32 is directly connected, Vlan60
C 172.200.7.0/24 is directly connected, Vlan70
L 172.200.7.254/32 is directly connected, Vlan70
C 172.200.9.0/24 is directly connected, Vlan90
L 172.200.9.254/32 is directly connected, Vlan90
192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.1.0/24 is directly connected, Vlan80
L 192.168.1.254/32 is directly connected, Vlan80
192.168.242.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.242.0/24 is directly connected, Vlan100
L 192.168.242.254/32 is directly connected, Vlan100
HQ#
On the layer-3 switch, did you create vlan 70
config t
vlan 70
exit
now check with "sh vlan" and make sure vlan 70 is part of the database. After this test again.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2021.03.16 23:38:08 =~=~=~=~=~=~=~=~=~=~=~=
Password:
HQ>ea na
Password:
HQ#sho vl
HQ#sho vlan
VLAN Name Status Ports
1 default active Gi1/0/10, Gi1/0/12, Gi1/0/38
Gi1/0/43, Gi1/0/44, Gi1/0/45
Gi1/0/46, Gi1/0/47, Gi1/0/48
Te1/1/1, Te1/1/2, Te1/1/3
Te1/1/4, Gi2/0/4, Gi2/0/9
Gi2/0/10, Gi2/0/12, Gi2/0/25
Gi2/0/38, Gi2/0/43, Gi2/0/44
Gi2/0/45, Gi2/0/46, Gi2/0/47
Gi2/0/48, Te2/1/1, Te2/1/2
Te2/1/3, Te2/1/4
10 IT active Gi1/0/26
20 Management active
30 Finance active
40 IPTelephony active
50 FingerPrint&IPCam active
60 WiFi active Gi1/0/9
70 Users active Gi1/0/17
80 DMZ active Gi1/0/11, Gi1/0/13, Gi1/0/14
Gi1/0/15, Gi1/0/16, Gi1/0/18
Gi1/0/19, Gi1/0/20, Gi1/0/21
Gi1/0/22, Gi1/0/23, Gi1/0/24
--More--
Gi1/0/28, Gi1/0/29, Gi1/0/30
Gi1/0/31, Gi1/0/32, Gi1/0/33
Gi1/0/34, Gi1/0/37, Gi1/0/41
Gi1/0/42, Gi2/0/11, Gi2/0/13
Gi2/0/14, Gi2/0/15, Gi2/0/16
Gi2/0/17, Gi2/0/18, Gi2/0/19
Gi2/0/20, Gi2/0/21, Gi2/0/22
Gi2/0/23, Gi2/0/24, Gi2/0/26
Gi2/0/27, Gi2/0/28, Gi2/0/29
Gi2/0/30, Gi2/0/31, Gi2/0/32
Gi2/0/33, Gi2/0/34, Gi2/0/35
Gi2/0/36, Gi2/0/41, Gi2/0/42
90 B1 active
99 test active
100 PureFlex active Gi1/0/25, Gi1/0/27, Gi1/0/36
Gi1/0/39, Gi1/0/40, Gi2/0/37
Gi2/0/39, Gi2/0/40
101 Linux active
199 test2 active
200 Signaling active
1002 fddi-default act/unsup
1003 trcrf-default act/unsup
1004 fddinet-default act/unsup
1005 trbrf-default act/unsup
--More--
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
10 enet 100010 1500 - - - - - 0 0
20 enet 100020 1500 - - - - - 0 0
30 enet 100030 1500 - - - - - 0 0
40 enet 100040 1500 - - - - - 0 0
50 enet 100050 1500 - - - - - 0 0
60 enet 100060 1500 - - - - - 0 0
70 enet 100070 1500 - - - - - 0 0
80 enet 100080 1500 - - - - - 0 0
90 enet 100090 1500 - - - - - 0 0
99 enet 100099 1500 - - - - - 0 0
100 enet 100100 1500 - - - - - 0 0
101 enet 100101 1500 - - - - - 0 0
199 enet 100199 1500 - - - - - 0 0
200 enet 100200 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 trcrf 101003 4472 1005 3276 - - srb 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trbrf 101005 4472 - - 15 ibm - 0 0
--More--  VLAN AREHops STEHops Backup CRF
1003 7 7 off
Remote SPAN VLANs
Primary Secondary Type Ports
HQ#
So, vlan 70 is the only vlan that is having issues? Can you ping the layer-3 interface on the switch? What switch can't reach vlan 70?
i try change TA IP device to vlan 10 but the same problem i cant reach.
thats why i told to you before to give you access.
what is on your mind ?
LinkedIN
thank you bro its working without any thing.
thank you very much
