Stack between c9200L 48 ports and c9200L 24 ports
Hi there,
I would like to know if is possible put in stack a C9200L 24 ports and C9200L 48 ports? same model but different amount of ports.
Reza Sharifi
As long as both switches are 9200L (which is your case) mixing them is not an issue.
Depending on the requirements of each switch in the stack, the Cisco Catalyst 9200 Series Switches provide the flexibility for mixed-mode support between different models in a single stack ring. You can mix switches with different model variants (PoE, data, Multigigabit) and different network modules in the stack; however, it is not possible to mix the9200 and 9200L models due to different stacking bandwidth.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9200-series-switches/nb-06-stackwise-architecture-cte-en.html
Reza Sharifi
