Connection Refused SSH WS-C2960S-48FPS-L
I'm very new to Cisco and this is my first configuring of one of their switches.  No matter what I do I'm unable to ssh into this switch.
Building configuration...
Current configuration : 4458 bytes
version 12.2
no service pad
hostname myswitch
boot-start-marker
boot-end-marker
enable secret 5 ********
username testuser privilege 15 secret 5 ********************
no aaa new-model
switch 1 provision ws-c2960s-48fps-l
ip domain-name mydomain.com
crypto pki trustpoint TP-self-signed-2432171264
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2432171264
revocation-check none
rsakeypair TP-self-signed-2432171264
crypto pki certificate chain TP-self-signed-2432171264
certificate self-signed 01
***key was here redacted**
quit
spanning-tree mode pvst
vlan internal allocation policy ascending
ip ssh version 2
interface FastEthernet0
no ip address
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface Vlan1
ip address 10.0.0.220 255.255.255.0
ip default-gateway 10.0.0.1
ip http server
ip http secure-server
ip access-list standard TELNET-ACCESS
permit 10.0.0.110
line con 0
password *********
login
line vty 0 4
access-class TELNET-ACCESS in
exec-timeout 5 0
password *********
login local
transport input all
line vty 5 15
password ******
login
transport input ssh
end
balaji.bandi
the high level you have access-list - only allowed IP 10.0.0.110  (are you using this IP to test ?)
if you have console access - remove ACL and test it.
line vty 0 4
no access-class TELNET-ACCESS in
line vty 5 15
BB
balaji.bandi
line vty 0 4
line vty 5 15
BB
Scott Leport
Level 7
Level 7
Hi there,
Best you check with your colleagues before removing that ACL as access to your equipment may be locked down to that host only.
But otherwise, I agree that's the issue. Either remove the ACL from VTY lines if permitted to do so or gain management access to your switch via this host only.
