[Connection to 10.0.0.1 closed by foreign host
i am trying to build ssh connection but i am constantly running errors. First of all I dont understand accessing with hostname or defining username and password. When i try to pen ssh connection i am getting error Connection to 10.0.0.1 closed by foreign host. Please help
Boss(config)#enable secret kics
Boss(config)#line vty 0 4
Boss(config-line)#password ccna
Boss(config-line)#transport input ssh
Boss(config-line)#login local
Boss(config-line)#exit
Boss(config)#ip domain-name caseStudy
Boss(config)#crypto key generate rsa
On user Side is type
Router>ssh -l caseStudy 10.0.0.2
Password:
% Login invalid
Password:
% Login invalid
Password:
Please help and guide
2 Accepted Solutions
This is the essence of your problem
line vty 0 4
password kics
login local
and
i am entering line console pswd
You are trying to use the line password but have configured the vty for login local which is expecting to authenticate with a locally configured user name and password. Either you need to configure a user name and password or you need to change the config of the vty to use the line password.
Rick
Assuming that you want to use the vty line password to authenticate then try this
line vty 0 4
no login local
login
and make sure that the configuration does not include aaa new-model.
Rick
11 Replies 11
balaji.bandi
have you created username and password:
username user1 password mypassword
enable password mypassword
BB
i am trying to access with domain name
and why it asks for password 3 times and then connection closed by remote host. which password i am supposed to enter.? i am entering line console pswd
post the full running configuration (sh run) of the BOSS device, as well as the output of:
sh ip shh
Boss#show running-config
Building configuration...
Current configuration : 793 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Boss
enable secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
ip cef
no ipv6 cef
license udi pid CISCO2901/K9 sn FTX1524RAL0-
spanning-tree mode pvst
interface GigabitEthernet0/0
ip address 10.0.0.2 255.0.0.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
password kics
login local
transport input ssh
line vty 5 15
password kics
login local
transport input ssh
end
line vty 0 4
password kics
login local
and
Rick
can you tell me how to configure line vty?
line vty 0 4
no login local
login
Rick
thanks it helped in ssh login. can you please guide me when i enter password for privildge mode it takes 3 attempts and then give error .. bad secret its not moving forward
Router>ssh -l caseStudy 10.0.0.1
Password: cisco
Boss>en
Password:
Password:
Password:
% Bad secrets
Boss>en
Password:
Password:
Password:
% Bad secrets
Boss>
This is a bit puzzling. The show run in a previous response shows an encrypted enable password. If you were able to make the config changes to get SSH to work then it would seem that you had the correct enable password. The enable password you used to make the config changes should work for SSH. If the enable password is not working with SSH I wonder if it might be something like caps lock being on?
Do you still have the ability to make config changes using the console connection? If so you might try changing the enable secret and then try the new password with SSH.
Rick
may be you need use line password
