Cisco QSFP-100G Bidi & (FN-TRAN-QSFP28-BIDI)
ENGBACHELOR
I have Cisco Nexus 9300 with (QSFP-40/100-SRBD) will be connected to fortinet device with (FN-TRAN-QSFP28-BIDI) SFP
will it work?
Ahmed
8 Replies 8
Reza Sharifi
BiDi is usually compatible with Cisco equipment and not other vendors.
100G and 40GBASE SR-BiDi QSFP Transceiver, LC, 100m OM4 MMF
Dear Reza
I have cisco device i want to connect to Fortinet device (FN-TRAN-QSFP28-BIDI), which SFP can work  (QSFP-40/100-SRBD) or (QSFP-100G-SR1.2 )?
Ahmed
Have a look at the compatibility matrix. I see QSFP-100G-SR1.2 listed for the different types of 9300 models.
https://tmgmatrix.cisco.com/?si=QSFP-100G-SR1.2&tpid=1622&npf=74
so (QSFP-40/100-SRBD) is the best choice to work with (FN-TRAN-QSFP28-BIDI)  Ok?
I would use "QSFP-100G-SR1.2" on the Cisco side since this is a standard optic and use FN-TRAN-QSFP28-BIDI on the Fortinet switch.
Have a look at the table in this link:
it appears you can use either one.
QSFP-40/100-SRBD
LC
QSFP-100G-SR1.2
100G SR-BiDi QSFP Transceiver, LC, 100m OM4 MMF
LC
yes, both QSFP-40/100-SRBD & QSFP-100G-SR1.2 are standard now
SamuelGLN
Yes, each Cisco QSFP 40/100-Gbps BiDi transceiver consists of two transmit and receive channels in the 832-918 nanometer wavelength range, enabling an aggregated 40 or 100-Gbps link over a two-strand multimode fiber connection. According FN-TRAN-QSFP28-BIDI's datasheet it'll work in link lengths of 100 and 150 meters on laser-optimized OM3 and OM4 multimode fibers, respectively.
https://www.fortinet.com/content/dam/fortinet/assets/data-sheets/Fortinet_Transceivers.pdf
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/datasheet-c78-736282.html
