Console Cable for SG250-10P
JFoster2020
Does anyone know where I would connect a console cable to a Cisco SG250-10P switch? Also, what kind of console cable to use?
Thank you.
balaji.bandi
cisco standard blue cable showuld work
"Cisco Console Cable 9-pin DB9 Female Serial RS232 Port to RJ45 Male Cat5 Ethernet LAN Rollover Console Cable Switch Cable Cisco (DB9-RJ45)"
BB
luis_cordova
Hi @JFoster2020
This device does not have console interfaces.
The configurations must be done, for the most part, through the GUI interface.
It also has a CLI interface, but you must access it through Telnet or SSH, keeping in mind that the available IOS is limited.
I leave you a couple of links for reference.
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbss/sf_sg250/quick_start/guide/en_US/78-100762-01A0.pdf
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/250_/2_4_5/cli_guide/cli_sx250_2_4_5.pdf
