11-14-2024 08:22 AM
Hello Everyone ,
i'm experiecning a problemr with a Cisco 3825 routers , i got a black screen when trying to console into devices ...
The same issue occurs with 2 differents devices (both 3825) .
i'tried to adjust the speed with many different values but same issue.
Already tried Putty, TeraTerm ,...
Do you know if there is anything to do in order to get a right console connection into thoses routers ?
11-14-2024 11:27 AM
I am sure you tested the console cable working other devices ?
make sure you connecting the console not management port ? (if the device has)
putty l always try this option it works :
Make sure device has power no other LED RED ?
=====️ Preenayamo Vasudevam ️=====
11-18-2024 01:11 AM
Hello ,
Yes i'm 100% sure of my Console Cable working on all other devices ,
Already tired with your settings , not working
Tried with another PC and another cable as well , i'm using a Console Cable with usb adaptor .
it's à Cisco 3825 router .
11-18-2024 01:43 AM
Try a different computer.
11-20-2024 11:43 AM
is the router booted and working ? do you have any other old console cable to test ?
what is other devices means ?
11-18-2024 02:34 AM
Already tried , same problem
11-20-2024 12:03 PM
Are these running systems currently?
Can you reboot one and do you see output during boot?
There is a no exec command that can be put on the console port that disables it, so if it is running and configured, you may be out of luck without wiping the config.
