Console on laptop without a serial port
jerry.mcrae
i have a IBM T-42 without a serial port. how can i console in? i have tried a console cable from cisco that has a 25 pin connection but no luck.
thanks in advance.
5 Replies 5
zatchmo04
You can buy USB-to-Serial adapters or PCMCIA-to-Serial adapters. I've used the USB adapters and they work quite well, and are relatively inexpensive.
is it plug and play?
Yes. Or at least the one I used was. :)
thisisshanky
Level 11
Level 11
Almost all USB to serial adapters are not really plug and play. You still need drivers for it which comes in a CD ROm. Of course you can store this in your laptop when needed or even on a USB jump drive. Most USB to serial adapters costs around 25-40 USD and you can pick them up at local stores like Frys, Best Buy or Circuit city.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
mark.mcsherry
I have used a USB - RS232 cable before and it worked fine.
One limitation though was that it couldn't send a break - if you need to do password recoveries, then the USB cable may not work for you . Just one to check on.
I think that some of the newer routers have USB connectors on them.
