control-plane command removed?
chris_whitlock
Visitor
I have a 3560 and upgraded from 12.2(46)SE to 12.2(58)SE and the control-plane command is now gone.  I can't find any specific documentation on the control-plane command and the SE train of code.
After upgrades, I have to explain differences in the configuration.  I work in the Utility Industry and have to meet NERCC/FERC standards.
Reza Sharifi
What specific commands are you looking for that is missing in 12.2(58)?
I was wondering if it was documented anywhere that the config command "control-plane" was removed?
3560 running 12.2(46)SE:
s201c-usc(config)#?
Configure commands:
  aaa                         Authentication, Authorization and Accounting.
  access-list                 Add an access list entry
  alias                       Create command alias
  archive                     Archive the configuration
  arp                         Set a static ARP entry
  banner                      Define a login banner
  beep                        Configure BEEP (Blocks Extensible Exchange
                              Protocol)
  boot                        Modify system boot parameters
  bridge                      Bridge Group.
  buffers                     Adjust system buffer pool parameters
  cdp                         Global CDP configuration subcommands
  cef                         Cisco Express Forwarding
  class-map                   Configure QoS Class Map
  clock                       Configure time-of-day clock
  cluster                     Cluster configuration commands
  cns                         CNS agents
  configuration               Configuration access
  control-plane               Configure control plane services
  crypto                      Encryption module
  default                     Set a command to its defaults
  default-value               Default character-bits values
3560 running 12.2(55)SE:
s021c(config)#?
Configure commands:
  authentication              Auth Manager Global Configuration Commands
  auto                        Configure Automation
                              Protocol)
  cisp                        Set CISP parameters
  clns                        Global CLNS configuration subcommands
  cns                         CNS agents
  cts                         Cisco Trusted Security commands
Any suggestions ?
I am having same issue with my 3560-x with c3560e-universalk9-mz.152-3.E2.bin
In summary, the issues is we cant enable control plane on the SW.
the command control-plane  is not accepted in global config mode.
Any update on this.  I had the same issue after upgrading to 12.2.58 SE2 as well.  It also doesn't show in the 15.0.2 SE10 as well and kicked the command out after updating to the new versions.  Is control-plane deprecated?
