STACKMGR-4-SWITCH_REMOVED: Switch 2 has been REMOVED from the stack
Mark Reynolds
This is on a 2960x flex stack.
I have checked with our TACACS server. No one was logged in at the time of reboot. Have checked the security cameras and no one was in the IT closet. Both units have separate UPS. Other devices on #2's UPS did not bounce. Googled these forums and found a few similar events from years ago that never went anywhere on ver 12.0. Hoping I will have some more luck. I'd like some suggested commands to run or any suggestions on tracking down this problem.
Basically as the subject says, switch2 is getting randomly removed from the stack. It reboots and rejoins the stack. This has been randomly happening for 3 days so I would like to get a direction to move in. Hopefully one that doesn't include replacing all the elements of this switch stack.
Show ver:
hostname-1d uptime is 2 days, 23 hours, 36 minutes
System restarted at 13:11:46 PDT Sun Aug 21 2016
sess 2
show ver:
hostname-1d-2 uptime is 4 hours, 35 minutes
System restarted at 08:14:38 PDT Wed Aug 24 2016
Switch Ports Model SW Version SW Image
* 1 28 WS-C2960X-24PS-L 15.0(2a)EX5 C2960X-UNIVERSALK9-M
2 28 WS-C2960X-24PS-L 15.0(2a)EX5 C2960X-UNIVERSALK9-M
8/24/2016 6:51:07 AM hostname-1d Error 208: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/28, changed state to up
8/24/2016 6:51:06 AM hostname-1d Informational 207: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45. (hostname-1d-2)
8/24/2016 6:51:02 AM hostname-1d Informational 206: %PLATFORM-6-FLEXSTACK_INSERTED: FlexStack module inserted in Switch 2. (hostname-1d-2)
8/24/2016 6:51:01 AM hostname-1d Notice 205: %STACKMGR-5-SWITCH_READY: Switch 2 is READ
8/24/2016 6:51:01 AM hostname-1d Notice 204: %STACKMGR-5-MASTER_READY: Master Switch 1 is READY (hostname-1d-2)
8/24/2016 6:51:01 AM hostname-1d Notice 203: %SYS-5-RESTART: System restarted -- (hostname-1d-2)
8/24/2016 6:51:01 AM hostname-1d Notice 202: %STACKMGR-5-SWITCH_READY: Switch 1 is READY (hostname-1d-2)
8/24/2016 6:51:01 AM hostname-1d Informational 200: %SYS-6-CLOCKUPDATE: System clock has been updated from 05:50:59 PST Wed Aug 24 2016 to 06:50:59 PDT Wed Aug 24 2016, configured from console by console. (hostname-1d-2)
8/24/2016 6:51:01 AM hostname-1d Notice 201: %SYS-5-CONFIG_I: Configured from memory by console (hostname-1d-2)
8/24/2016 6:51:01 AM hostname-1d Informational 199: %SYS-6-CLOCKUPDATE: System clock has been updated from 13:50:59 UTC Wed Aug 24 2016 to 05:50:59 PST Wed Aug 24 2016, configured from console by console. (hostname-1d-2)
8/24/2016 6:51:01 AM hostname-1d Notice 198: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan (hostname-1d-2)
8/24/2016 6:51:01 AM hostname-1d Notice 197: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down (hostname-1d-2)
8/24/2016 6:51:01 AM hostname-1d Warning 196: %STACKMGR-4-SWITCH_ADDED: Switch 2 has been ADDED to the stack (hostname-1d-2)
8/24/2016 6:51:01 AM hostname-1d Warning 195: %STACKMGR-4-SWITCH_ADDED: Switch 1 has been ADDED to the stack (hostname-1d-2)
8/24/2016 6:51:01 AM hostname-1d Informational 194: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2960x_lanbase Next reboot level = lanbase and License = lanbase (hostname-1d-2)
8/24/2016 6:51:01 AM hostname-1d Warning 193: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state UP
8/24/2016 6:51:01 AM hostname-1d Warning 192: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 2 has changed to state UP
8/24/2016 6:51:00 AM hostname-1d Notice 191: %STACKMGR-5-SWITCH_READY: Switch 2 is READY
8/24/2016 6:50:53 AM hostname-1d Warning 190: %STACKMGR-4-SWITCH_ADDED: Switch 2 has been ADDED to the stack
8/24/2016 6:50:07 AM hostname-1d Warning 189: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state UP
8/24/2016 6:50:07 AM hostname-1d Warning 188: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state UP
8/24/2016 6:46:47 AM hostname-1d Notice 187: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/28, changed state to down
8/24/2016 6:46:47 AM hostname-1d Notice 186: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/19, changed state to down
8/24/2016 6:46:47 AM hostname-1d Notice 185: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/18, changed state to down
8/24/2016 6:46:47 AM hostname-1d Notice 184: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/17, changed state to down
8/24/2016 6:46:46 AM hostname-1d Error 181: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/19, changed state to down
8/24/2016 6:46:46 AM hostname-1d Error 179: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/17, changed state to down
8/24/2016 6:46:46 AM hostname-1d Notice 183: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/1, changed state to down
8/24/2016 6:46:46 AM hostname-1d Error 178: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/1, changed state to down
8/24/2016 6:46:46 AM hostname-1d Error 182: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/28, changed state to down
8/24/2016 6:46:46 AM hostname-1d Error 180: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/18, changed state to down
8/24/2016 6:46:44 AM hostname-1d Warning 177: %STACKMGR-4-SWITCH_REMOVED: Switch 2 has been REMOVED from the stack
8 Replies 8
Jose Solano
Level 4
Level 4
This is normally an issue with either a bad stack cable or a bad stack port, check the link below on how to address this:
Resolving StackWise Connection Problems
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/troubleshooting/switch_stacks.html#wp39183
HTH,
Jose
So we have gone ahead and replaced both the cable and flexstack modules on both switches. The problem just showed up again today. Any advice beyond swapping the units?
Can you post a show version ?
Jose
cs697-1d#show ver
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.0(2a)EX5, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Mon 16-Feb-15 08:16 by prod_rel_team
ROM: Bootstrap program is C2960X boot loader
BOOTLDR: C2960X Boot Loader (C2960X-HBOOT-M) Version 15.2(2r)E1, RELEASE SOFTWARE (fc1)
cs697-1d uptime is 1 week, 2 days, 3 hours, 3 minutes
System image file is "flash:/c2960x-universalk9-mz.150-2a.EX5/c2960x-universalk9-mz.150-2a.EX5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960X-24PS-L (APM86XXX) processor (revision F0) with 524288K bytes of memory.
Processor board ID FOC1919W2D0
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
56 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : B0:7D:47:D7:8D:80
Motherboard assembly number : 73-15972-02
Power supply part number : 341-0528-01
Motherboard serial number : FOC19183NJQ
Power supply serial number : LIT19130R2H
Model revision number : F0
Motherboard revision number : C0
Model number : WS-C2960X-24PS-L
Daughterboard assembly number : 73-14200-03
Daughterboard serial number : FOC19156KJ8
System serial number : FOC1919W2D0
Top Assembly Part Number : 800-41469-01
Top Assembly Revision Number : C0
Version ID : V02
CLEI Code Number : CMMLR00ARB
Daughterboard revision number : A0
Hardware Board Revision Number : 0x12
Switch 02
Switch Uptime : 6 hours, 59 minutes
Base ethernet MAC Address : B0:7D:47:D7:9E:00
Motherboard serial number : FOC19183PF0
Power supply serial number : LIT19130SPB
Daughterboard serial number : FOC19192B0G
System serial number : FOC1919W2D7
Top assembly part number : 800-41469-01
Top assembly revision number : C0
Version ID : V02
Configuration register is 0xF
cs697-1d-2#show ver
cs697-1d-2 uptime is 7 hours, 0 minutes
System restarted at 09:16:17 PDT Tue Aug 30 2016
export@cisco.com.
Processor board ID FOC1919W2D7
Version ID : V02
Thanks, there is a bug that causes silent reloads on 2960X POE units and on the last reload reason you will see "power-on".
Based on the show version you may be hitting that issue. The bug is internal thus you wont be able to see the details, ID CSCus47446. I suggest that if you have a service contract, go ahead and open a TAC case to get assistance with that and a confirmation of the bug.
HTH,
Jose
Leo Laohoo
Says here switch member 2 had a power reload.  So it's either the following culprit:
1.  System crash;
2.  Power supply about to fail;
3.  Human intervention.
In regards to #1, post the complete output to the command "dir flash2:".
In regards to #2, explain how power is applied to the stack.
1. No crash file...
cs697-1d#dir flash2:
Directory of flash2:/
2 -rwx 1329 Jul 22 2015 13:02:21 -07:00 express_setup.debug
3 -rwx 15858 Jun 27 2016 11:38:19 -07:00 config.text
4 -rwx 1456 Aug 30 2016 02:17:37 -07:00 vlan.dat
5 -rwx 14579 Jun 27 2016 11:38:19 -07:00 config.text.backup
6 -rwx 2008 Jun 27 2016 11:38:19 -07:00 private-config.text
7 drwx 512 May 9 2015 07:50:39 -07:00 c2960x-universalk9-mz.150-2a.EX5
646 drwx 512 May 9 2015 07:50:40 -07:00 dc_profile_dir
648 -rwx 2008 Jun 27 2016 11:38:19 -07:00 private-config.text.backup
649 -rwx 1048 Nov 16 2015 22:36:37 -08:00 multiple-fs
2: Power supply about to fail :
Power supplied via UPS. UPS is running many additional elements in the network rack and does not appear overutilized as far as power goes. Power cables and power ports were swapped with flexstack cable/modules. (We have 4 seperate UPS)
3. Unit is in a locked rack in a locked room and video camera shows no human bodies at reboot time.
So probably the power supply?
I guess it is time to swap out units. Any thoughts on if I should swap the secondary first or them both at the same time?
No crashinfo sub-directories so this is not a crash.
Sounds like a UPS issue, a power rail or the power supply of the switch.
