Control Plane Policing CDP
fsebera
Level 4
Level 4
I am trying to police cdp traffic (amound other traffic types) on my border routers 2800 series.
When I setup the class-map to include cdp I receive an error.
class-map COPP_4
match protocol arp
match protocol cdp
Unsupported protocol in 'match protocol'
Here is the policer configlet:
class COPP_4
  police 256000 4000 conform-action transmit  exceed-action drop
I see some folks mention layer-2 protocols ALWAYS fall into the class-default, but arp is accepted (without error) so I am not sure.
Any ideas?
Tks
Frank
smehrnia
Level 7
Level 7
Hi there,
try using this match clause under the class-map: match access-group name system-cpp-cdp see if you have this predifined ACL for cdp, not sure if its there for C2800 !
plz Rate if it helped,
Soroush.
Hope it Helps!
Soroush.
Nada; I also checked my ASR1002 routers 15.x IOS and the match access-group name syntax exist but no preconfigured names (system-cpp-cdp) exist.  Is there something I need to enable first to have the preconfigured options to show up?
Tks
Frank
actually i've seen this work on cisco 4500 chasis. wasnt sure if ur device supports it.
by the way I did extensive research n could not find a thing to match CDP in a class map, i think what u said earlier, class-default is where u got CDP. bind the service policy to control-plane cef-exception.
i think its best to limit ARP and other packets for CoPP using pps rate (packet per sec.) instead of bit rate, in policy-map.
Hope it Helps,
Soroush.
Hope it Helps!
Soroush.
