"trust device cisco-phone" on Lan Lite ios
Sergey Balyura
hello, all!
I have some 2960 switches with Lan Lite ios in my infrastructure.
And I try to configure them to support "trust device cisco-phone" and "switchport priority extend cos 0" on ports with cisco phones.
But Lan Lite image does not support "mls qos trust device cisco-phone"
can I use any workaround to trust cos of cisco phone and to remark PC traffic with cos 0?
Thankx in advance.
nkarthikeyan
Level 7
Level 7
have you tried auto qos feature for voip????
But certainly lite ios has limited features only... you cannot upgrade to the other.... dats de main problem.... but i guess it supports the vlan based qos configuration... there also you can specify voip traffic for cisco phones and make it work....
