Controller Port Error
sanjee108
Visitor
I have a cisco 3560 switch PoE, with cisco wireless access points connected to it. I got 9 access points out of 24 go off.  I got the following log for all off ports.
3w6d: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/32: Power given, but Power Controller does not report Power Good
Show power inline command output is below.
Interface Admin  Oper       Power   Device              Class Max
                            (Watts)
Gi1/0/32  auto   off        0.0     n/a                 n/a   30.0
I reset the port by shut & noshut.
Reset the power by pow inline never & pow inline auto.
But link is still down.
What can I do next?
Leo Laohoo
Do this:
1.  Command:  test cable tdr interface Gi1/0/32;
2.  Wait for approximately 5 to 7 seconds;
3.  Command:  sh cable tdr interface Gi1/0/32; and
4.  Post the complete output to #3.
6 Replies 6
Leo Laohoo
Do this:
Hi Leo
Thank you.
Did the test. following are the results of all off ports. Suspecting cable faults and will arrange the cable inspection.
Interface Speed Local pair Pair length        Remote pair Pair status
Gi1/0/22  auto  Pair A     N/A                N/A         Normal
                Pair B     N/A                N/A         Normal
                Pair C     1    +/- 10 meters N/A         Open
                Pair D     N/A                N/A         Normal
Sanjee,
The cable fault is nearest the switch.  Check the patch cable connected to port Gi1/0/22 first.
NGC-U2A-00-ASW-0001#sh cable-diagnostics tdr interface g2/0/3
TDR test last run on: August 24 01:17:15
Gi2/0/3 100M Pair A N/A N/A Not Completed
Pair B N/A N/A Not Completed
Pair C N/A N/A Not Completed
Pair D N/A N/A Not Completed
What platform is this?
louwvaneeden
Community Member
I had the same problem. Had a fibre converter with ethernet cable plugged into port.
Replaced the power supply on fibre converter and everything worked fine. I suspect when fibre converter
power supply blew it tried to get power from the switch.
