Conversion from point to point to VRRP configuration on Catalyst switch
bberry
Hello all,
I am trying to learn VRRP and figure out how to convert from using point to point networks between my router and switch over to using VRRP. I normally take a switch port, use the no switch port command and give it one side of the point to point networks. If I have more than one router connected I simply repeat the process using a different point to point network. I can then do things like have a static route from the core to the other side of the point to point.
Now the fun begins and it may be because I have never had to do something like this. We are moving over to a backup method with our provider that uses VRRP. This seems to basically be configured the same as HSRP and they have given me interface configuration samples.
track 1 interface (wan interface) line protocol
track 2 ip route (customer network or host & subnet) reachability  *** optional ***
inteface ( LAN Interface )
desc LAN interface to custoner LAN
IP address ( LAN IP address & Subnet mask)
vrrp 1 description primary active GRP 1
vrrp 1 IP ( Virtual IP address)
vrrp 1 preempt delay minimum 20
vrrp 1 priority 110
vrrp 1 track 1 decrement 15
The issue I am having though is how do I configure things on the switch side? I will have two interfaces that need the same address space. One being my primary router and the other being the backup device. If I try my standard method and configure two ports in the same address space I will get the network overlap message. Am I trying to make this too complicated and need to simply create a VLAN and use that interface for the VRRP configuration stuff?
Thanks in advance...
Brent
Reza Sharifi
On the switch side, just put all the ports in the same vlan, create an SVI (layer-3 interface) and configure VRRP.
