CoPP confiugration issue with ASR 1001
ncfb-awarsame
I'm configuring CoPP for an ASR 1001 router with consolidated IOS XE Version: 03.07.01.S.  And I'm trying to use 'DROP' command under policy map to drop
un wanted traffic. But the drop command is not listed. Did Cisco remove it or I'm doing something wrong here?
Thank you
internet-rtr2(config)#policy-map CoPP
internet-rtr2(config-pmap)# class CoPP-pre-undesirable
internet-rtr2(config-pmap-c)#?
Policy-map class configuration commands:
  aaa-accounting   AAA Accounting
  account          Account statistic
  bandwidth        Bandwidth
  compression      Activate Compression
  exit             Exit from QoS class action configuration mode
  fair-queue       Enable Flow-based Fair Queuing in this Class
  netflow-sampler  NetFlow action
  no               Negate or set default values of a command
  police           Police
  priority         Strict Scheduling Priority for this Class
  queue-limit      Queue Max Threshold for Tail Drop
  random-detect    Enable Random Early Detection as drop policy
  service-policy   Configure QoS Service Policy
  set              Set QoS values
  shape            Traffic Shaping
2 Accepted Solutions
srereddy
Hey.....drop is not a valid command on ASR IOS XE. It was never available. If it is mentioned in any cisco document, then its a documentation error. You need to use it with a policer - e.g. police 90000 conform-action transmit exceed-action 'drop'
HTH.
Just use this workaround  -
police cir
      conform-action drop
      exceed-action drop
      violate-action drop
Or as shown in  -
use
http://www.cisco.com/en/US/docs/ios/ios_xe/qos/configuration/guide/ctrl_plane_policng_xe.html#wp1027265
Router(config-pmap)# class icmp-class
Router(config-pmap-c)# conform-action drop
PS: Rate the post if it helped
6 Replies 6
srereddy
HTH.
thank you- but I don't want to police that traffic. I want to drop it like I'm doing with 3825 IOS router.  Is there another way to do it?
police cir
      conform-action drop
      exceed-action drop
      violate-action drop
Or as shown in  -
use
Thank you
You are welcome. Glad to help. Pls tag this as 'answered' if you are satisfied (and dont forget to rate it). :-)
thank you
