Devices are not responding connected to switch WS-C3750X-48
In My Network we are using switch WS-C3750X-48 as a network management switch . where all the devices are connected only for management purpose which includes(routers, switches, firewalls and load balancers).
Here im facing strange issue that only load balancers(multiple) are not reachable/pingable , even though the ports are showing up and i dont see any errors on the ports everything looks good.
we are using Brocade ADx4000 load balancer
i logged into the load balanacer via console, i dont see any issue on the management port, i checked with vendor brocade even they also couldnt find any issue , we done packet capture on the load balancers they informed that LB is sending broadcast packet  but switch is not responding back..
i checked with cisco also regarding this they asked us to upgrade the IOS from C3750e-universalk9npe-mz.122-55.SE3 to C3750e-universalk9npe-mz.122-55.SE5 as they are seeing some bug.
i done the IOS upgrade on the switch but still iam getting the same issue .. as a temporary workaround , i need to do manually bounce the port to make it work.
Please help me in fixing this issue .. your help will be much appreciate..
5 Replies 5
cadet alain
could you post your switch config.
Regards.
Alain
Attached the configuration ,
Load balancers are connected on port Gi1/0/35-39
how often is the problem happening ? Can you provide the output of the brodcast frames from the LB?
Since when have you got the problem , was the switchport block multicast was already there before when it was working ?
Regards.
Alain
1)                    We are facing this issue max of span of 2 weeks..., 2)   we noticed the issue last 3 months of time.. 3) yes switch port block multicast was configured before when its wokring..
I attached the capture which we took on LB...
I don't see any ARP  requests for the vlan interface from load balancer in first capture.
so unless it is doing proxy-arp it will not respond to such requests, i'm gonna take a look at other captures.
Regards.
Alain
