Copp & Coppr on ISR 4331
clark white
Level 2
Level 2
Dears,
I want to apply copp and coppr on my router, I know the commands and the way to apply but I don't know what should be classified for the copp and coppr, in other words what I shld analyze so that I can called those stuff in class-map  for copp and coppr
thanks
8 Replies 8
Reza Sharifi
Here is a sample config you maybe able to use.
https://skminhaj.wordpress.com/2016/02/16/copp-control-plane-policing/
Dear Reza,
Any configuration example for CoPPr , Any blog or post in which it makes easy understand to configure and apply coppr for the routers.
thanks
I have never heard of coppr and not sure what that is.
Dear Reza,
Here is the link which says about cPPr
http://www.cisco.com/c/en/us/td/docs/ios/12_4t/12_4t4/htcpp.html#wp1096911
Dears
I dont get any control-plane host or transit or cef-exceptional command in 4331 IOS xe router
-CPE01(config)#control-plane ?
  <cr>
You you need to enter the control-plane mode first. Than under control-plane you will see the option for service-policy.
Dear Reza,
i can see the service policy but if i want to enter to control-plane host sub interface instead of other sub-interface for example transit, cef-exception so how i can do that i dont get such options to do that.
Pls refer to the link below
http://www.cisco.com/c/en/us/td/docs/ios/12_4t/12_4t4/htcpp.html#wp1082734
Hi all,
do you have any update regarding the topic? I have the same problem on a 4331, I even tried to activate the securityk9 license (EvalRightToUse) but it seems it doesn't support control plane subinterfaces configuration...
Thanks in advance!
