Copy config from Cisco 3750G 24-Port to Cisco 3750X 48-Port Switch
dcgtechnologies
I am trying to figure out if it is possible to copy the config from a Cisco 3750G 24 Port to a Cisco 3750X 48-Port Switch. This is for a switch replacement. Does anyone know the proper steps to get this done? I understand you can can use a TFTP server, but is it even possible without going through each line of the config and manually doing it. Any help would be appreciated. Thank you.
15 Replies 15
Leo Laohoo
NOTE:  Remember that you're exporting a 24-port config into a 48-port config.
The easiest way is to enable terminal or console logging and then do this:
1.  term len 0
2.  sh start (or sh run)
This will create a txt file in your computer.
Log into the 48-port and paste the config or copy the config in via USB flash drive.
