07-17-2017 10:11 AM - edited 03-08-2019 11:21 AM
Hi all,
I have some 3560's that are in service that need to be swapped out with 3750's. Is there a way to copy over the current configs from the 3560's to the 3750's without having to rebuild the config files from scratch?
Brian
07-17-2017 10:57 AM
You can copy the running config from the 3560s to a tftp server and than load it from tftp server into 3750s, but the problem is that the port numbering for 3560 is different than the 3750 series. For example; port 0/10 from a 3560 is 1/0/10 on a 3750. I think, you may need to copy the config from each switch to a notepad, make all the changes you need to make and than paste it to the 3750.
Also, between the 2 platforms most commands are the same but you may see some commands that work on a 3560 but not on a 3750 and vice versa.
07-20-2017 10:16 AM
HTH,
Thank you for the help. I ended up redoing it any way. When I uploaded the newly configured file to another switch however, the switch isnt allowing vlan2 or 3 to come up now. Not sure what I messed up. I will post the config in a bit.
Brian
07-26-2017 10:45 AM
Quick question,
I rebuilt the config files on my spare 3750 for each different switch and saved each config file. When I went to upload the new config files to the switches I needed to change, vlan2 and vlan3 stay down. Is there something I am missing?
Brian
07-26-2017 10:49 AM
So, in the old switch vlan 2 and 3 worked fine but not in the switch?
Can you post the new config?
"sh run"
07-26-2017 08:39 PM
Creating interface vlan X will not create VLAN X.
VLAN on switch in transparent or server VTP (vtp domain and password must match) mode is created by issuing commands
vlan x
or
interface fa0/0
switchport mode access
swithcport access vlan x
additionally, for SVI to be in up up state VLAN need to have at least one active port (can be vlan assigned to trunk).
Tshoot commands:
show interface status
show interface trunk
show vlan brief
show spanning-tree vlan x
