copy flash config
cisconoobie
Level 2
Level 2
I know there is a command in the recent IOS that allows you to copy a past config and have it over-write the current config.
Does anyone know what that is?
copy flash:my_config run - will only copy contents and they will be merged, but what is the command to copy and over-write fully without merging?
John Blakley
config replace flash:config run
HTH,
John
HTH, John *** Please rate all useful posts ***
John Blakley
HTH,
John
