Copy flash TFTP Error (timed out) - solarwinds.
terrelstinnett
I am trying to copy my IOS to my pc using Solarwinds.
Solarwinds is Started.
I am able to ping from my pc to the fa0/1 port on my switch.
These are in the same subnet.
Pinging 192.168.1.100 with 32 bytes of data:
Reply from 192.168.1.100: bytes=32 time<1ms TTL=255
Reply from 192.168.1.100: bytes=32 time=2ms TTL=255
Ping statistics for 192.168.1.100:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 2ms, Average = 0ms
Switch(config-if)#do ping 192.168.1.50
Sending 5, 100-byte ICMP Echos to 192.168.1.50, timeout is 2 seconds:
Here is the error...
Switch#copy flash tftp
Source filename []? c3550-ipbasek9-mz.122-25.SEB4.bin
Address or name of remote host []? 192.168.1.50
Destination filename [c3550-ipbasek9-mz.122-25.SEB4.bin]?
%Error opening tftp://192.168.1.50/c3550-ipbasek9-mz.122-25.SEB4.bin (Timed out)
appreciate any help.
Please check if have firewall enabled on the PC. If it is enabled disable it or open port 69 ofr tftp.
Best regards,
Alex
*Please rate helpful posts.
Best regards,
Alex
God bless. been working on this for days.
hello,
The same error here. but I am able to copy a different file like a sample text file (text.txt) from tftp to flash
Please help..
I too had this problem.
When I was trying to copy from tftp to flash , the transfer would start and then would terminate in the middle and would give the error "timed out"
I could even see in the tftp server logs that the transfer was happening and suddenly stopped. I was using tftpd32
Later I found out the reason to be duplex mismatch
I went to interface config and then corrected the duplex setting and the transfer happened perfectly.
Hope this response helps those for whom transfer stops due to this error.
