Copy Run Start Problem
mikntwd49508
Community Member
when running "copy running-configuration startup-configuration, I get the following error.
%Error opening flash:running-configuration (File not found)
6 Replies 6
Edison Ortiz
Please post your 'show version' from this device .
Can you also try the command 'wr mem' and see if it works ?
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(4)XC4, RELEASE SOFTWARE (fc1)
Synched to technology version 12.4(5.13)T
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 24-Jul-06 18:33 by ealyon
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
ROM: Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(4)XC4, RELEASE SOFTWARE (fc1)
DPI-CME-2811 uptime is 16 weeks, 1 day, 23 hours, 31 minutes
System returned to ROM by Reload Command
System restarted at 08:53:53 EDT Wed Mar 14 2007
System image file is "flash:c2800nm-advipservicesk9-mz.124-4.XC4.bin"
That's not a complete 'show version'. I was looking for the current config-register setting.
Please repost the entire show version.
Did you try 'wr mem' as suggested ?
Can you also post the output from typing
'show priv'.
HI,
Its better to capture & attach the complete output of "show tech-support" for full - analysis.
Best Regards,
Guru Prasad R
WR MEM
DPI-CME-2811#wr mem
Building configuration...
Compressed configuration from 29043 bytes to 13778 bytes[OK]
Show Version
DPI-CME-2811 uptime is 16 weeks, 1 day, 23 hours, 52 minutes
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2811 (revision 53.51) with 247808K/14336K bytes of memory.
Processor board ID FTX0908A12N
2 FastEthernet interfaces
25 Serial interfaces
1 terminal line
2 Channelized T1/PRI ports
2 Virtual Private Network (VPN) Modules
2 Voice FXO interfaces
1 cisco service engine(s)
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62592K bytes of ATA CompactFlash (Read/Write)
DPI-CME-2811#
SHOW PRIV
Current privilege level is 15
Edison Ortiz
Gosh, I can't believe I overlooked the obvious.
The command is
copy running-config startup-config
not
running-configuration will be treated as a file name.
