copy running config http
vishalpatil86
I have used this command but i dont know where to find the config file
i gave my localhost ip
Pls help on this
Reza Sharifi
This command will copy your running config to whatever server IP or name you give it:
example:
Switch#copy running-config http:
Address or name of remote host []? 10.10.10.1
Destination filename [switch-confg]?
In this case 10.10.10.1 is your server address
hi reza,
Thank u for  the reply.. But at what location it is saved in 10.10.10.1?
