Copy Running Configs
greg8
We have Cisco 3750 switch that will be replaced by Cisco Nexus 9000 series.  The new Nexus chassis is pretty much the same.  I was wondering if there would be any issues with uploading the config files from the 3750 to 9000?  The physical connections won't change.  I would like to do this instead of configuring each port one at a time.  I did notice on our 3750 switch that ports look different like:   3750-GigabitEthernet1/0/1   Our existing Nexus-Ethernet1/33, will I have to edit the config file for this change?
balaji.bandi
Cat Switch and Nexus Switch syntax bit different ?
Are you replacing Stack or standalone switches ?
best is :
1. Copy running config to NotePad
2. Take new Nexus switch test one.
3. run the basic setup of nexus and copy major config you have from 3750 to Nexus 9000 ( check the syntax change)
check IOS to nexus converter :
https://nxmt.cloudapps.cisco.com/design.htm?_flowId=home-flow&_flowExecutionKey=e1s1
BB
The 3750 is a stack switch and is being replaced by a standalone Nexus N9K-C93108TC-EX.
Just asked since you replacing STAck with Nexus (then you need make vPC) since you confirmed they go as standalone is good.
BB
