Core 3: CPU utilization High in 3650 switch (process fed , PunjectRx)
End user complains about performance in LAN. sw core is  3650- 24TS running 03.06.04.E (cat3k_caa-universalk9.SPA.03.06.04.E.152-2.E4.bin).
After checking CPU, the results are:
MX#sh processes cpu sorted
Core 0: CPU utilization for five seconds: 5%; one minute: 5%;  five minutes: 5%
Core 1: CPU utilization for five seconds: 1%; one minute: 1%;  five minutes: 1%
Core 2: CPU utilization for five seconds: 1%; one minute: 1%;  five minutes: 1%
Core 3: CPU utilization for five seconds: 98%; one minute: 99%;  five minutes: 99%
PID    Runtime(ms) Invoked  uSecs  5Sec     1Min     5Min     TTY   Process
5803   35859       42251829 951    25.41    25.48    25.48    1088  fed
8670   3156690     55050125 174    0.79     0.99     1.00     0     iosd
8666   3852611     17193591 14     0.20     0.14     0.15     0     wcm
5804   183268      17678926 17     0.10     0.05     0.05     0     platform_mgr
5538   2907012     47473458 151    0.05     0.02     0.03     0     system_mgr
_MX#sh processes cpu detailed process fed sorted
Core 0: CPU utilization for five seconds: 6%; one minute: 5%; five minutes: 5%
Core 1: CPU utilization for five seconds: 2%; one minute: 1%; five minutes: 1%
Core 2: CPU utilization for five seconds: 7%; one minute: 2%; five minutes: 1%
PID    T C  TID    Runtime(ms) Invoked uSecs  5Sec      1Min     5Min     TTY   Process
5803   L           118399      4225216 951    25.40     25.52   25.49   1088  fed
5803   L 3  9178   939971      1481490 0      24.57     24.74   24.73   0     PunjectRx
5803   L 2  6245   211694      2341549 0      0.25      0.25    0.25    0     fed-ots-nfl
5803   L 1  6242   3002181     3037472 0      0.15      0.18    0.18    0     fed-ots-main
5803   L 0  6268   3416966     1853120 0      0.15      0.04    0.04    0     IntrDrv
5803   L 0  9176   4127906     2194402 0      0.15      0.15    0.15    0     Xcvr
5803   L 2  9179   3958775     2488082 0      0.15      0.13    0.13    0     PunjectTx
_MX#show mgmt-infra trace messages   fed-punject-event
[12/04/16 21:13:26.021 cst 11eb23f4 5803]
TX: DI lookup exercised, al_di: 0x5493e618 di type: 3, rsc_type 1, dst MAC: 58:20:b1:db:f7:2a
[12/04/16 21:13:27.446 cst 11eb23f5 5803]
[12/04/16 21:13:28.161 cst 11eb23f6 5803]
TX: DI lookup exercised, al_di: 0x5493e618 di type: 3, rsc_type 1, dst MAC: f0:1f:af:6:95:ff
[12/04/16 21:13:29.503 cst 11eb23f7 5803]
TX: DI lookup exercised, al_di: 0x5493a0e8 di type: 1, rsc_type 1, dst MAC: ff:ff:ff:ff:ff:ff
[12/04/16 21:13:29.859 cst 11eb23f8 5803]
TX: DI lookup exercised, al_di: 0x5493e618 di type: 3, rsc_type 1, dst MAC: 18:66:da:e6:49:96
I try to understand  the reason  this processes  are high  and how I can avoid.
I have found others discussion with high CPU  process but there is no clear explanation for PunjectRx
I planning to reload the switch based on the recommendation in one discussion I found.
any  recomendtion?
regards
Reza Sharifi
Before you reboot the switch, contact Cisco TAC and open a ticket so they can look into the issue. If you reboot the switch before doing that, they may not be able to trace what is wrong with switch as it maybe a hardware or software issue.
sdipippo
It's very likely bug ID CSCuz57493. Upgrade code to fix. 3.6.6E has the fix.
habookans
