Shutting down or blocking a switch port
Is it possible to shut down or block a switch port if the Ethernet cable is disconnected from a host connected to that port?
David Hild
Level 11
Level 11
Any Ethernet interface can be administratively shutdown regardless of the connectivity status of that interface.
I hope this is helpful.
Yes, it does. Thanks you for your help.
