12-19-2012 02:12 PM - edited 03-07-2019 10:42 AM
Hi All,
I have a setup with two Cat 4506E working as a HA,
I used a bundle 4Gb interfaces working as ether-channel,
I'm facing a problem with DHCP pools on the both SW's,
There is no problem if I use the pools on one sw,
But when I but the pool on both sw's then I faced a lot of conflict IP in the DHCP pools,
How can setup a real DHCP redundancy on both SW's,
Thanks in advanced for your effort,
Ahmed,
Solved! Go to Solution.
12-20-2012 06:16 PM
You can configure different pool space to avoid DHCP conflict.
Example:
Sw1:
int vlan 15
ip addr 10.0.0.2 255.255.255.0
standby 15 ip 10.0.0.1
ip dhcp excluded-address 10.0.0.1 10.0.0.3
ip dhcp excluded-address 10.0.0.128 10.0.0.254
ip dhcp pool sw1
net 10.0.0.0 255.255.255.0
default-router 10.0.0.1
Sw2:
int vlan 15
ip add 10.0.0.3 255.255.255.0
ip dhcp excluded-address 10.0.0.4 10.0.0.127
ip dhcp pool sw2
12-19-2012 02:36 PM
When you say HA, you mean VRRP, HSRP?
12-20-2012 04:09 PM
Dear Reza,
Many thanks for your reply,
Yes I mean HSRP,
Ahmed
12-20-2012 06:16 PM
Example:
Sw1:
int vlan 15
ip dhcp pool sw1
Sw2:
int vlan 15
ip dhcp pool sw2
12-21-2012 02:31 AM
Dear Abzal,
Many thanks for your advice,
It's really very smart solution,
But is there any other solution to have full DHCP pool redundancy?
Thanks in advanced,
Ahmed,
12-21-2012 02:48 AM
Glad to help. Actually there is a solution Cisco CNS Registar. But unfortunately I don't experience working with this system. I cannot tell much about it however it provides DHCP/DNS failover.
http://www.cisco.com/en/US/products/sw/netmgtsw/ps1982/index.html
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps5698/ps1982/data_sheet_c78-634879.html
Hope it will help.
12-21-2012 03:39 AM
Dear Abzal,
Many thnaks for your reply,
Yes it's really help me,
I appreciate all your effort,
Many thanks,
Ahmed,
