CoS and Ethernet and Trunking Question
mmedwid
Level 3
Level 3
I've been doing some Cisco training and question came up "Is CoS supported in Ethernet?"  I had presumed so
but the answer said that CoS was only supported on 802.1q and ISL trunks.  So my question is - if you configure
"auto qos" on an access switch port (say a 3750POE) and phone VLAN with a phone attached what is the
effect on the frames?  Or is it the case that auto qos in this case is working at layer 3 and modifying the
DSCP first three bits?  Thank you for clarifying!
Jon Marshall
An access port will accept a tagged frame if -
1) the vlan ID is set to 0 (which is what the phone actually does)
or
2) the vlan ID is set to the vlan the access port has been assigned to
So the phone will send tagged frames (with vlan ID = 0) to the switch. The 802.1p (CoS) markings will be contained within the 802.1q tag.  The phone will also set the DCSP marking in the packet as well.
Jon
5 Replies 5
Jon Marshall
or
Jon
Thanks much Jon.
Hi Jon,
needing a clarification: isn't  CDP telling the VLAN the phone is a member of and then when the phone sends frames they are tagged with this VLAN id? all of this if we set the auxiliary vlan with the switchport voice vlan "id" command and if we configure sw voice vlan dot1p then the VLAN id will be zero?
Regards.
Alain.
Alain
You are correct. CDP is used with Cisco phones and the auxiliary vlan. I was answering from a more generic perspective, probably because my only experience of VOIP has been with Nortel !!, so in that case it was vlan ID = 0 etc. But in the case of a cisco phone yes CDP is used to sort all this out.
Jon
Hi Jon,
Thanks for info as I've never worked with phones other than Cisco ones.
Regards.
alain.
