Cos vs DSCP
dcanady55
Level 3
Level 3
I've been searching the web and forums for awhile and cannot seem to find the answer to my questions regarding this topic. It seems there is a wide variety of opinions out there and was hoping someone could clear up my confusion.
To start I'm talking about 2960-x Cat. Switches
My phone vendor recommends I perform QoS at L2 and L3. This would require me to trust COS at the interface level and I'm not sure why. If I trust DSCP at the interface level this will be end to end. If a PC sitting behind a phone (none cisco btw) sends a COS value this will get remarked to DSCP zero correct? I know there's some risk for a PC to manipulate it's traffic to set DSCP to 46 besides that fact why else would I care to trust COS? From my understanding most applications wouldn't set a COS value nor have I sniffed any that send DSCP yet. If I was going to use NBAR to further break out my traffic it would be a the router level.
11 Replies 11
Meghna Muralinath
Hi Derek,
When you enable qos on the switch and look at the "sh mls qos" on the switch
2960X#sh mls qos
QoS is enabled
QoS ip packet dscp rewrite is enabled ------------------------> observe here that dscp re-write is enabled.
Disable this if you do not want the dscp value of the packet from being overwritten.
Command : 2960XR(config)#no mls qos rewrite ip dscp
aalejo
Level 5
Level 5
Your vendor recommends to trust cos on switch  because Cisco Phone can not write down DSCP on incoming packets on its PC port: They can only rewrite PC packet cos down to cero. Then, if you trust DSCP on switches, PC software can mark traffic at will on any DSCP and affect voice traffic for example. In other words Cisco cares "more" for ip phone voice traffic.
Joseph W. Doherty
"My phone vendor recommends I perform QoS at L2 and L3."
Yea, such a recommendation is "book" correct, but many Enterprise Cisco "L2" switches, like the 2960 series, can use L3 ToS for QoS purposes.  You would only need to consider using L2 CoS when switch cannot use L3 ToS.  Also, at least between switches, L2 CoS requires VLAN tagged frames.
"If a PC sitting behind a phone (none cisco btw) sends a COS value this will get remarked to DSCP zero correct?"
What remarks, the VoIP phone or the ingress switch port?  For either, it would depend on the VoIP phone or the switch.  Traditionally, older Cisco switches would, by default, remark L2 and/or L3 CoS/Tos to zero, but newer switches, I believe, now don't, by default.  (Don't know about a 2960X, might also depend on IOS version.)
"I know there's some risk for a PC to manipulate it's traffic to set DSCP to 46 besides that fact why else would I care to trust COS?"
Again, you would only need to use L2 CoS when you cannot process L3 ToS.
As to a device using DSCP EF incorrectly, the easiest approach I've come across is to police such traffic at about 100 Kbps.  If they want to send, for example, FTP at 100 Kbps, network likely can handle that, just as it would for a VoIP G.711 at 100 Kbps.  If host tries to send VoIP and FTP, concurrently at 100 Kbps, they might find their VoIP doesn't work too well.  (So don't send something like FTP with DSCP EF.)
"From my understanding most applications wouldn't set a COS value nor have I sniffed any that send DSCP yet."
Yup, most apps don't except for VoIP and/or some video.
The main issue is that cisco considers PC and PC traffic (by definition) something that network equipment can not control and can not trust then, on "best" Cisco Qos practices, QOS trust boundary should ends on the phone.
A better solution (but maybe unfeasible) will be try to work w directory control policies to enforce QoS on PC/ server generated traffic and allow the network to follow QoS marked traffic for queuing and prioritization.
Since Cisco does not reach directory control policies his controls ends on the phone itself. Then, their best practices is not to trust whatever is connected to PC sends and rewrite traffic. Because of $$ ,Cisco phone does not rewrite DCSP and they have design the solution for switches to do the rewriting but this creates a complexity since there must some kind of trusting on traffic sends by phones.  On Switches  if you trust DSCP (Layer 3 trust), then all traffic that comes from PC is trusted (Cisco solution does n want that) and if you trust Cos (layer 2 trust), all traffic send by PC that traverse phone gets remarked to zero and phone traffic gets unchanged. That's the reason they recommend using conditional L2 trusting.
The other solutions that Cisco suggest is to access list on the edge but, anyone that had manage a network, realized how complex this is,
the boundary is not because cisco not trust PC but because PC send frame un-tag and hence PC can not add CoS to frame
when PC behind Phone and you use mini trunk then Phone send tag and hence can use CoS
OK can I use DSCP?
it depend if the SW can read IP header or not
so boundary is depend on your network capabilty
MHM
Is  a common misconception thinking that PC can not send tagged frames when on access vlan but  it can.  When PC needs to send traffic with CoS only (for priority) it will send sent it on 802.1Q (VLAN 0) and whatever CoS you need. Switched will recognize that traffic as belonging to the the untagged vlan assigned to the port and will give priority if configure.
The boundary is exactly where you trust and  you don't trust: Thats exactly the definition
I know PC can send tag vlan' but if you have 1000 of PC then you need to config all to send tag frame.
I am talking that by defualt PC send un-tag frame.
MHM
You said (and to be clear) "the boundary is not because cisco not trust PC but because PC send frame un-tag and hence PC can not add CoS to frame".  That is not correct: QOS Boundary is to define a trust limit for QoS trusting /marking/re-marking. QoS boundary is a concept that can be enforce depending on each device capacity.
Configure a 1 PC or 1 million to send tag frames  can be as easy as pushing a policy on a domain.
QOS design guide was not made to handle only default  PC configuration: is made to try to address all possible scenarios (including not default ones). As a matter of fact, there is a command on switch that request phone to overwrite traffic send with different Cos by PC.
"The main issue is that cisco considers PC and PC traffic (by definition) something that network equipment can not control and can not trust then, on "best" Cisco Qos practices, QOS trust boundary should ends on the phone."
Oh, can you provide a reference to that information?
Usually, a trust boundary is at a demarcation where there's a change in administrative control.  As edge ports, especially user end jacks, are not under my control, I consider that a trust boundary.  Doesn't matter whether there's a VoIP phone or not.  Again, especially on user edge ports, every one has a VoIP phone?  No PCs are using a software VoIP phone?  What precludes someone from connecting a different device to the wall plate jack?  I don't recall VoIP phone usually controlling CoS/ToS to/from an end host, in fact, PCs are usually on a non-tagged VLAN, as might a VoIP phone (another reason L2 CoS is "iffy").  (BTW, yes, there are edge access control technologies, but I'm assuming cases where we don't have such.)
So, typically, a user edge port should be a trust boundary.  (Also, connection to another AS network device, should also be a trust boundary.)
"A better solution (but maybe unfeasible) will be try to work w directory control policies to enforce QoS on PC/ server generated traffic and allow the network to follow QoS marked traffic for queuing and prioritization."
Certainly a possible and worthwhile approach, but I wouldn't depend on that alone.  (Personally I'm paranoid.  So "trust but verify" is always a good approach, as it catches "accidents" too.)
"Then, their best practices is not to trust whatever is connected to PC sends and rewrite traffic."
Again, trust but verify, I believe is a better approach.  Whatever you receive from an edge port could be totally valid, and doesn't need to be remarked (actually from a different AS, marking might be totally valid but need to be remarked because you use different markings for same purposes), but even if that's the case, we now know it's valid markings on our side of the trust boundary.  (Again, for simplicity, I've used critical markings, like DSCP EF, without validation, but controlled in such a way, it doesn't matter to my QoS goals.)
"On Switches  if you trust DSCP (Layer 3 trust), then all traffic that comes from PC is trusted (Cisco solution does n want that) and if you trust Cos (layer 2 trust), all traffic send by PC that traverse phone gets remarked to zero and phone traffic gets unchanged."
Again, any Cisco references?  (As that's not my understanding of Cisco recommendations, nor how Cisco devices' QoS work, by default.  [NB: Cisco default QoS handling does vary, between their switches and routers, and with switches, between old and new - if you're unware of this, I can described their basic differences and also why I think they chose the defaults they did.])
"That's the reason they recommend using conditional L2 trusting."
Again, reference please.  Possible you have in mind implicit trust of Cisco VoIP phones using CDP to place themselves on a voice VLAN.  (Even that approach, I would not endorse an implicit trust, although it's convenient.  Of course, I don't generally endorse Auto-QoS, which is also convenient.)
"The other solutions that Cisco suggest is to access list on the edge but, anyone that had manage a network, realized how complex this is,"
Well actually, my last job, before I retired, was in an environment of 5,000 Enterprise devices, with 100,000 plus users (my responsibility was about 1/10 of that), so yea, somewhat acquainted with interface configurations, but complexity wasn't the issue, just number of interfaces to configure.  For edge QoS, often we had both ingress and egress policies, so mass QoS changes was a bit of a hassle (at that time, this was before some of the modern configuration packages [so we also wrote our own scripts for mass changes - new deployments not much of a problem - you learn to love the range option].)
BTW, when it comes to QoS, I'm a legend in my own mind (laugh).  Consider me a QoS god (small case), or maybe a QoS demigod (laugh.)  Seriously, though, for what was at the time, the 4th largest software development firm in the world, I spend about half my time, over 10 years, working on QoS.  It's amazing how much it can contribute to a well working network, but unfortunately, 99% of "book" QoS recommendations will not get you a well working network.  About the only thing basic "book" QoS does well is handle RT traffic like VoIP or video conferencing (since they dump such traffic into PQ or LLQ [but much often isn't said about what else should be considered for that traffic]).
If you're interested in QoS working well, let me know, and what your QoS goals are.  Very possibly, I can help you have effective QoS beyond what you "read" in most QoS books.  (BTW, I've also read many books and articles on QoS, started with them, in fact, and spend a good bit of time working out why they didn't work well in a real international network, and what to do instead.)
Hey Joseph, to be exact when i reference to Qos boundary i am referring to Qos trust boundary. Is reference on many Cisco documents and design guides.
This is one of the typical pictures that Cisco places on all his design documents. Definitions is inside there and i have read it multiples times. Sorry can not be more precise in the middle of many things.
Later i will extend my answer.
No surprises in that diagram.
#1 has Cisco extended trust to Cisco VoIP phone because (as I noted earlier) due to CDP.
#2 Has phone using CoS 5 and 3.  Many (non-Cisco, Cisco?) VoIP phones will also mark ToS too, regardless whether CoS is available.
#3 Cisco VoIP phone does NOT change PC CoS (assuming PC uses tagged frames).  PC more likely to use ToS, and wouldn't expect VoIP phone to remark that either.
#4 Cisco switch trusts VoIP CoS and maps into ToS.
#4, I believe requires an auto qos variant, like auto qos trust cisco-phone.  There's much that goes along with using auto QoS, so don't confuse what a switch's non auto QoS vs. auto QoS behaviors are.
