Could not use "speed 10Mbps" and "duplex full" on 6504E
Hai Dao Tuan
Hi all
Our company are using connection between 6504E (VSS) and WAN switch 2960S by the default configuration of speed and duplex (speed auto, duplex auto). Current configuration and connection please check in attached files
Due to the limitation of WAN access line, so we want to set the speed of connection to 10Mbps and duplex full
But when we applied the configuration
interface range Gx1/y1, Gx2/y2, ...
  speed 10
  duplex full
the interfaces on all SWs are down
Gi1/4/36                       down           down     WANSW_2960S
Gi1/4/48                       down           down     WANSW_2960S
Gi2/4/36                       down           down     WANSW_2960S
Gi2/4/48                       down           down     WANSW_2960S
Po64                           down           down      WANSW_2960S
If we used duplex auto, so the links are up. But my boss required to use "duplex full"
Please support or advice me the reason I cannot use the static setting "speed 10, duplex full" on both sites of SWs
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Unsure if it applies to the 2960S (or 6500), but on some devices auto/auto also supports auto-MDI.  On those, if you hard code speed/duplex, you need to insure you're using the correct cable; cross-over for switch-to-switch.
Joseph W. Doherty
Disclaimer
Posting
Tks Joseph
Last time I did also think about that, but because we didn't order cross-cable cables so I checked on both SWs site and retried to enter "mdix auto" command (for sure only). So you mean that even auto-MDIX has been enabled, but if I hard code speed/duplex, the auto-MDIX will be disabled by default?
Disclaimer
Posting
I believe that's generally the case.
