Couldn't Clear Bus
nanang
We have problem in Nexus 3064PQ 10GX,
2021 Sep 11 04:50:03 NX-MMR-LDP3 Sep 11 04:38:20 %KERN-2-SYSTEM_MSG: [701137.055200] clk_flush: Couldn't Clear Bus, Attempt 2 of 5 - kernel
2021 Sep 11 04:50:03 NX-MMR-LDP3 Sep 11 04:38:20 %KERN-2-SYSTEM_MSG: [701137.055220] clk_flush: Couldn't Clear Bus, Attempt 3 of 5 - kernel
2021 Sep 11 04:50:03 NX-MMR-LDP3 Sep 11 04:38:20 %KERN-2-SYSTEM_MSG: [701137.055241] clk_flush: Couldn't Clear Bus, Attempt 4 of 5 - kernel
2021 Sep 11 04:50:03 NX-MMR-LDP3 Sep 11 04:38:22 %KERN-2-SYSTEM_MSG: [701139.067808] clk_flush: Couldn't Clear Bus, Attempt 1 of 5 - kernel
2021 Sep 11 04:50:03 NX-MMR-LDP3 Sep 11 04:38:22 %KERN-2-SYSTEM_MSG: [701139.067958] clk_flush: Couldn't Clear Bus, Attempt 1 of 5 - kernel
2021 Sep 11 04:50:03 NX-MMR-LDP3 Sep 11 04:38:22 %KERN-3-SYSTEM_MSG: [701139.068055] neutron_usd/3469 - failed to set mux addr 0x73 ch 64 err I2C_
ERR_SMBUS_FAILED  - kernel
LDP3# show system resources
Load average:   1 minute: 1.48   5 minutes: 1.42   15 minutes: 1.42
Processes   :   331 total, 4 running
CPU states  :   13.50% user,   43.00% kernel,   43.50% idle
        CPU0 states  :   12.00% user,   17.00% kernel,   71.00% idle
        CPU1 states  :   15.00% user,   69.00% kernel,   16.00% idle
Memory usage:   3665240K total,   2329168K used,   1336072K free
NX-MMR-LDP3# show processes cpu sort
Please note that only processes from the requested vdc are shown above
PID    Runtime(ms)  Invoked   uSecs  1Sec    Process
3380      2631072   3410977    771  38.40%  syslogd
3416     58778284  1446204879     40   7.15%  bcm_usd
3524      5003137  36946856    135   7.15%  snmpd
3654          372      1005    370   6.25%  netstack
3382      1905831   8800817    216   3.15%  pfma
3670      2034701  16774533    121   2.70%  ethpm
3431      1307149  64584448     20   2.25%  klogd
3600          171        46   3729   1.35%  arp
LDP3# show processes cpu sort | ex 0.00
3380      2636268   3414954    771  38.75%  syslogd
3416     58803869  1446558377     40  12.10%  bcm_usd
3654          372      1005    370   5.34%  netstack
3453      9850517  13575464    725   3.40%  statsclient
3431      1317772  65120942     20   1.95%  klogd
3600          171        46   3729   1.45%  arp
3469      1877556   2646688    709   0.94%  neutron_usd
    4       221006   3082321     71   0.50%  ksoftirqd/0
3477       358060   7032761     50   0.50%  fwm
3747      4648932  78672341     59   0.50%  stp
Any idea guys?
Mark Elsen
 - Probably a bug , check current software version , upgrade and or use an advisory release , if applicable.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
check if the bug below applies:
N3064: continue clk_flush: Couldn't Clear Bus - kernel and I2c access failed - neutron_usd errors
CSCvn34433
Description
Symptom:
A N3064 may report continuous clk_flush: Couldn't Clear Bus - kernel or neutron_usd I2c access failed errors when Eth1/49-52 QSFP ports are used as 40Gig or used as 10Gig breakout.
2018 Nov 16 20:12:16.042 N3064 16 20:12:03 %KERN-2-SYSTEM_MSG: [38998325.685862] clk_flush: Couldn't Clear Bus - kernel
2018 Nov 16 20:12:16.047 N3064 16 20:12:03 %KERN-3-SYSTEM_MSG: [38998325.685867] neutron_usd/3485 - failed to set mux addr 0x73 ch 16 err I2C_ERR_CLKFLUSH_FAILED - kernel
2018 Nov 13 23:38:57 N3064 %USER-2-SYSTEM_MSG: neutron_usd_i2c_prsnt_check:617: I2c access failed for port 50 - neutron_usd
2018 Nov 13 23:38:57 N3064 %USER-2-SYSTEM_MSG: neutron_usd_i2c_prsnt_check:617: I2c access failed for port 51 - neutron_usd
2018 Nov 13 23:38:57 N3064 %USER-2-SYSTEM_MSG: neutron_usd_i2c_prsnt_check:617: I2c access failed for port 52 - neutron_usd
2018 Nov 13 23:38:57 N3064 %USER-2-SYSTEM_MSG: neutron_usd_i2c_prsnt_check:617: I2c access failed for port 49 - neutron_usd
Conditions:
There are 2 conditions which can trigger these errors.
1. A faulty of wrongly seated QSFP/QSA used in ports (1/49-52) may generate continuous interrupts and cause the I2C bus to hang. - this is addresses via bug CSCuy12344 which can help to identify the port which caused the I2C errors instead of trying re-seat of one QSFP/QSA at a time to narrow down the faulty QSA/QSFP
2. Requesting for DOM data for the optics inserted in port 1/49-52 can hold the I2C bus for longer time and generate the I2C errors - the fix in this bug is addresses this issue.
Workaround:
Stop SNMP polling for DOM data or stop executing "show interface transceiver detail" command to avoid requesting DOM data.
Further Problem Description:
1. Due to busy I2C bug, the show version output may give an error message.
2. The PS and Fan Tray may report as missing/faulty, but they're working fine.
Once I2C errors are cleared, these issues also get cleared.
