couldn't establish channel on CATOS
azmath.hk
Dear NetPro team,
We are trying to connect one of our access switch which are running on CATOS with distribution switch which are running on IOS but couldn't work out. The attached are the configuration from our distribution switch dont know much about CATOS commands; hence could you please review the attached configuration which is from of distribution switch and help us out with CATOS configuration for access switch.
Network topology is as follows:-
DS1 (9/7 and 8/7) (1/1 and 2/1) access switch
I see that interface Gigabit Ethernet 8/9 and Gigabit Ethernet 9/9 are in shutdown mode. Why?
Best regards.
Massimiliano.
Because I dont know how to set port channel and configure those ports as a trunk on CATOS
Ok.
Look at EtherChannel Between Catalyst Switches Running CatOS and Cisco IOS Software : http://www.cisco.com/en/US/tech/tk389/tk213/technologies_configuration_example09186a0080094953.shtml
I hope this helps.
Massimiliano.
