CP 2.7 viewing problem
Gernot Krems
Community Member
hi @ all!
i have a viewing problem by my CCP 2.7.
i only see the first 30% of the screen, the rest is hidden!
i´ve tried a lot of IE settings but nothing helped ...
i also tried it with my Google Crome but i had the same problem!
Gernot K.
System: win7 pro
Browser: IE10
Marvin Rhoads
Lots of folks have encountered this with IE10 or later. Since the application uses the IE controls (dlls and such in Windows), using different browsers won't help. Fortunately, it has been discussed on the Network Management forum and a work around found. Please refer to the following threads: link 1, link 2.
Hope this helps.
Marvin Rhoads
Hope this helps.
YOU ARE THE MAN!
thx
Gernot
